HomeReviewsAmp and DAC ReviewsLuxsin X8 Review: A Powerful Intelligent DAC/Amp for Modern Audiophiles
Finding the right desktop DAC/amp is about more than just improving sound; it’s about building a system that enhances how you experience your entire music library. Whether you’re pairing it with high-end headphones or upgrading from a basic setup, the ideal unit should offer a balance of power, precision, and flexibility without overcomplicating the listening process. The Luxsin X8 intelligent DAC/amp enters this space as a modern all-in-one solution, aiming to deliver strong performance alongside intuitive features that adapt to a wide range of headphones and listening preferences.
  • Luxsin X8 intelligent DAC/Amplifier
  • Power Cable
  • USB-B to USB-A cable
  • Quarter-inch adapter
Luxsin X8 headphone plugs
Build
In terms of pure looks, the Luxsin X8 is an extraordinarily well-constructed DAC/Amp that makes a perfect fit for any desktop surface. The Luxsin X8 is constructed with a strong emphasis on durability and premium fit and finish, centered around a solid CNC-machined aluminum chassis that gives the unit a dense, high-end feel while also aiding in heat dissipation during extended use. The exterior features a clean matte finish and precision-cut design elements, contributing to a minimalist but refined desktop presence that aligns with other modern audiophile components. The front panel is slightly angled (around 15°), improving the visibility and usability of the touchscreen interface in a desktop setup. Overall, the construction feels purpose-built for long-term reliability, combining robust materials with thoughtful industrial design rather than purely aesthetic flair.
The Luxsin X8 provides you with two balanced and one unbalanced headphone out, 4.4mm, 4-pin XLR, and quarter-inch. On the back, you have USB-A, B, and C ports for audio in, along with coaxial and optical. For audio outputs, the X8 has both RCA and XLR.
Luxsin X8 rear
The Luxsin X8 is built as an all-in-one desktop audio hub, combining a high-end digital-to-analog converter, powerful headphone amplification, and advanced DSP processing in a single chassis. At its core is an eight-chip Cirrus Logic CS43198 DAC array arranged in a true dual-mono configuration (four DACs per channel), designed to improve dynamic range, reduce noise, and enhance detail retrieval. It’s paired with a robust amplifier stage using OPA1612 op-amps and TPA6120A2 drivers, delivering up to roughly 4.8W per channel for driving demanding headphones. The X8 also integrates a proprietary Digital Audio Core (HiFi-5 DSP + ARM architecture), enabling real-time processing and features like AI-assisted parametric EQ and a headphone database with thousands of profiles for tailored sound optimization.
The Luxsin X8 allows you to play with sound in a few different ways. There’s EQs, filters, crossfeed, and dynamic range enhancement. As a DAC, it has a lot of potential to put its own flavor into the sonic profile of your headphones. As an amplifier, the X8’s auto-impedance detection, headphone gain control, and volume step make for easy pairing with most audiophile headphones. I started my testing by connecting a pair of Audeze LCD-5s through their 4-pin XLR balanced connector. The X8 delivers an output that easily maintains the superb balance and separation that makes the LCD-5 well-regarded.
Nothing feels enlarged or expanded, just a faithfully synergized representation of the headphone’s sound signature with slightly more surface area and weight in its low-mid tone. It’s not an added warmth, but a more subtle gain to certain frequencies that makes the LCD-5 slightly fuller. It’s interesting then, that this resposne is taken away when activating crossfeed. With crossfeed on, the X8 makes the LCD-5 sound thinner and airier. The soundstage is more holographic, and individual performances are still highly separated, but the spatial imaging now has a more apparent center. On the flip side, pan movements are given more of a spotlight, worming around your head in a way you don’t normally hear headphones replicate. Stereo width is also slightly reduced, but the X8 has a built-in width control in its effect setting to help combat this.
After the LCD-5, I switched to the Sennheiser HD 660S2, where I really got to see what the impedance matching can do. As soon as I plugged in the HD 660S2, using a Strauss & Wagner Nyon cable attached so I can continue to use a balanced output, the display immediately activated the impedance matching. It read the impedance as 300 Ohms and adjusted itself in a matter of seconds, putting the HD 660S2 at the same level of gain as the headphones I had just listened to.
You get a lot of headroom as a result, expanding the clarity of the loudness and revealing more detail. The treble received the most notable enhancements, appearing sharper both definitionally and texturally. It’s an interesting trade-off that is dependent on track selection, but nothing was ever too harsh. Certain high-end tones just appeared brighter than usual, and I’ve never heard the HD 660S2 sound so shimmery.
The Luxsin X8 intelligent DAC/amp succeeds in bridging the gap between technical sophistication and everyday usability. Its eight-chip DAC array and powerful amplification stage provide a clean, controlled foundation that scales effortlessly with demanding headphones, while its DSP features like crossfeed, EQ, and impedance matching offer a level of customization rarely this seamless. What makes the X8 particularly compelling is how it enhances rather than overrides a headphone’s natural character, adding subtle refinement instead of artificial coloration.
For listeners seeking a desktop DAC/amp with high output power, balanced connectivity, and intelligent sound tuning, the Luxsin X8 stands out as a forward-thinking option. It’s not just a tool for driving headphones—it’s a system designed to adapt, refine, and elevate your entire listening experience.
The Luxsin X8 is available at Audio46.
