With the release of the D8000 DC, enthusiasts and audiophiles alike are presented with two compelling options from Final Audio that promise exceptional sound quality and design. The D8000 Pro and DC utilize advanced planar magnetic technology and cutting-edge acoustic engineering, making them ideal choices for those who demand the best in audio performance. In this review, we will dive deep into both models’ features, construction, and sound quality, allowing you to determine which set of headphones suits your personal listening preferences.
| D8000 Pro | D8000 DC |
The D8000 Pro and DC are both constructed in the same basic style. You get the obvious differences with the DC’s silver finish next to the Pro’s black with silver accents. On closer inspection, both headphones have different types of padding for both the earcups and padding. With the Pro, the headband uses leather, while the ear pads use another material. The DC version uses a special Washi material for both its earpads and headband, which are thicker than the Pros. What may surprise you is that the DC is far lighter than the Pro by about 120g. I bet that most people will find the DC more comfortable than the Pros, but the Pros are still comfortable in their own right.
Both headphones use similar driver configurations, with planar magnetic drivers and Final Audio’s AFDS (Air Film Damping System) technology. Each headphone is tuned differently, of course, with the DC version aiming to tackle transient response more directly. An improved acoustic chamber also improves signal flow within the housing. They can both be played at high playback volumes with no identifiable degradation to the signal.
One of the major differences between these two editions of the D8000 is their spaciousness and depth. It’s hard to imagine how different these headphones could possibly be, but after A/B testing them, there’s a clear winner for me. If you prefer a wide, close, intimate soundstage, you might prefer the Pro. However, the DC is also wide and far more open. Its spatial imaging communicates more depth through its holographic presentation, while the Pro version displays a stricter stereo field. Both headphones feature tons of precision and individualized positioning, but I find the DC to have more wrap-around and height. You might not enjoy the DC’s floatier imaging though, in which case, the Pro’s will feel more exact and realistic. When I listen to both D8000 headphones I can’t help but keep returning to the DC for its immersive quality.
Tonally, there are a lot more similarities than differences in the bass. Both versions of the D8000 have a prominent mid-bass that punches deep and blooms on a large scale. If we’re going by technicalities, the DC seems to have a better extension than the Pro, with slightly more transparency, but that’s only if you’re really looking for it. In terms of timbre, both headphones exhibit a stacked bass response with plenty of texture and detail. There’s slightly more shape to the DC, but the foundation of the bass is similar to the Pro.
The similarities continue into the midrange, where the DC and Pro frequency responses are relaxed. With that said, I would consider the D8000 Pro to be closer to V-shaped than the DC. The DC doesn’t seem like it has the dip that the Pro has, even if they’re tonally similar. You get a more dominant warmth from the DC, which adds more flavor to the timbre than the Pro. There are lusher qualities to it that express a more energetic performance, while the Pro version does a better job communicating evenness.
There is more direct brightness when listening to the Pro version of the D8000 compared to the DC. I think both headphones are comparable in detail retrieval, but the Pro brings everything more to the front of the mix, while the DC has a smoother amplitude. The advantage of the DC though is its superior treble height while maintaining a clear presence. If you need the high frequencies to be more energetic and sparkly, the Pro will offer more, but the DC might be better for pure enjoyment.
When choosing between the D8000 Pro and D8000 DC headphones, it ultimately comes down to your specific audio needs and preferences. The D8000 Pro excels in delivering a precision-focused sound, making it perfect for those who appreciate strict stereo imaging and vivid highs. On the other hand, the D8000 DC offers an immersive soundstage that engulfs you in rich textures and smooth warmth, ideal for listeners seeking a more enveloping auditory experience. Both models boast outstanding build quality and are equipped with specialized driver technology, ensuring that every note is reproduced with clarity and depth. Regardless of your choice, you can be confident that you’re investing in top-tier headphones that will enhance your listening journey.
The Final Audio D8000 Pro and D8000 DC are available from Audio46.
