HomeReviewsHeadphone ReviewsNAD Viso HP70 Wireless Headphones Review
When you’re willing to spend $400 on a wireless pair of headphones, you’re expecting a high quality product with superior sound, physical design and easy portability. Does the VISO HP70 check all of these boxes? Let’s find out out in this NAD Viso HP70 Wireless Headphones Review.
IN the BOX – NAD Viso HP70 Wireless Headphones Review
Travel Clip
Micro USB Cable
Ribbon Cable
¼” Stereo Adaptor
Airline Adaptor
DESIGN and FEATURES – NAD Viso HP70 Wireless Headphones Review
The VISO HP70 looks like my parents’ furniture from the 80’s. But the 80’s are in! Plush black  leather meets shiny and smooth contoured silver. They’re a little heavy and bulky, so I wouldn’t give them high marks for portability, especially since they don’t fold.
They have very effective active noise cancelling, HD Bluetooth and Near Field Communication, which is the same technology that enables Apple Pay.
SOUND – NAD Viso HP70 Wireless Headphones Review
The VISO HP70 is a good all-rounder. You get a reasonably balanced headphone with deep lows and pleasant highs. It’s an easy and smooth listening experience that does well with most genres. Let’s take a look at the breakdown…
The bass on the HP70 very deep, especially with the active noise cancelling feature on. It has a subwoofer feel. Think of your body vibrating as a kid passes you in a hydraulic car. It’s not a very dry, gripping bass. It resonantes a bit. A wetter sound. Not necessarily a bad thing. But the bass has more of a feeling than clear texture.
The upper-mids are there, but the lower mids are bit lacking because the lows drown them. Does it take away from the listening experience? If you’re listening to a big rock or pop-rock chorus, then yes. But I don’t want to be too hard on these poor cans. They’re still quite well balanced, pleasantly smooth, and do a good job in most genres with respect to the midrange.
No sizzle or piercing highs, which is the most important thing for me. The highs have a nice roundness to them. Strings and woodwinds don’t sound very forward, but are easy to listen to. High percussion and guitars are clear and quite detailed for a wireless headphone.
I like the soundstage on these NADs. I definitely felt some width, but no depth. Still, horizontal instrument placement sounded pretty accurate. Spacious.
SUMMARY – NAD Viso HP70 Wireless Headphones Review
The sound on these headphones is good. But I think they’re a little overpriced. They seem like an experimental prototype that just missed the mark. I’ve heard better sounding wireless headphones that are cheaper than the VISO HP70. The physical design is also a little impractical. Check out the Sony WH-1000xM2 instead. Better portability, sound and all-around value for money.
You can find the NAD Viso HP70 for the best price at:
Audio 46: NAD Viso HP70 Wireless Noise Cancelling Headphones Use our promo code “majorhifi” to get a 10% discount
Amazon: NAD Viso HP70 Wireless ANC Headphone featuring RoomFeel in Black
SPECIFICATIONS – NAD Viso HP70 Wireless Headphones Review
Frequency Response:
LF Cutoff -10dB – 10Hz to 20,000Hz
LF Cutoff -3dB – 15Hz to 20,000Hz
Within ±1.5dB – 20Hz to 20,000Hz
Impedance: 32 Ohms
Weight: 320 grams
Dan Clark Audio AEON Core vs Noire X Comparison Review
Dan Clark Audio has built a strong reputation for making closed-back planar headphones that feel compact, comfortable, and technically advanced. Two of its most...
