HomeReviewsAudiophile ReviewsDan Clark Audio Aeon Core Review: A Spacious Closed-Back Planar
Dan Clark Audio has a long history of making planar magnetic headphones that appeal to audiophiles and serious listeners. With the Aeon Core, the brand introduces a closed-back model that aims to bring its signature design and sound philosophy to a more approachable package. It enters a competitive space for listeners who want premium build quality, everyday comfort, and a more refined listening experience. Let’s take a closer look at its design, fit, and sound to see how it performs.
  • Aeon Core closed-back planar headphones
  • Choice of 4-pin locking cable
    • Quarter-inch, 4-pin XLR, and 4.4mm Dummer or VIVO
  • Cleaning cloth
  • Drawstring bag
  • User guide
Dan Clark Audio Aeon Core headband
The Aeon Core is less like Dan Clark Audio’s Noire headphones and more like a more affordable version of the E3. It combines both aluminum and wood for one of Dan Clark’s most interesting designs, using these new materials and incorporating them into the Aeon series framework. This also makes the Aeon Core one of the heavier Dan Clark headphones in their lineup, which makes a weird counterbalance for their usual self-adjusting suspension headband. The ear cups don’t clamp down in any significant way, though, which makes up for the increased pressure on your head. This overall makes for a comfortable fit, allowing me long listening sessions without much fuss.
Dan Clark Audio Aeon Core above
The Aeon Core is built around a newly developed planar driver design. This is paired with a low 17-ohm impedance and approximately 97 dB/mW sensitivity, making it easier to drive than many traditional planar headphones. This new driver platform also supports the AEON CORE’s revised Harman-target tuning, aiming for a more balanced and accessible sound while preserving the resolution and bass control expected from a planar magnetic headphone.
Dan Clark Audio Aeon Core side
The best part of listening to the Aeon Core was definitely hearing how expansive its soundstage was. For a closed-back headphone, the Aeon Core is incredibly wide and spacious, giving instruments plenty of room to breathe, separated by blank spaces for them to be easily localized in the stereo field. The Aeon Core is super impressive with how it layers complex arrangements so effortlessly.
Everything comes across as clean and organized, stacking layers of sound with cavernous dimension, all while showcasing a clear channel identity from left to right. Barely anything in the mix sounds like it’s coming from the middle of your head. Even instruments that don’t have any pan information and are truly in the middle of the mix either come from below or above your headspace. It’s quite an immersive sound environment to experience, hearing sounds hover around your headspace and wrap around to completely engulf you in a track’s spatial components.
If you’re looking for a big bass response from the Aeon Core, you might be disappointed. While the lows have some clarity from the foundation of the bass tone, it never seems to hit very hard. Bass notes can have some vigor to them, but the timbre is always very neutral. On the right tracks, where there’s a strong bass instrument, like an upright bass or an electric string bass, the lows emerge with depth and body. However, the response is still very soft, and when these specific elements aren’t present, the lows are barely noticeable.
Most of the meat of the Aeon Core’s sound signature is going to be in the midrange. There’s no real warmth to it, but the evenness and tactility of the frequencies bring out some good detail. It’s not very transparent, though, as the timbre of the mids comes with a tonal dryness that I haven’t heard on a lot of headphones recently. The Aeon Core just has a fullness to its midrange that makes it the sound signature’s biggest spotlight. That comes with mostly positive attributes, like roominess and balance, but it also leads to some frequency bands having a slight veil, especially in the upper-midrange.
The treble is very forgiving on the Aeon Core. They have some light airiness to them that makes them appear floaty in their presentation. This increases the height of the Aeon’s sound signature to great effect, elevating the high frequencies to occupy their own space. It allows them to tail off naturally, never congealing with the mid-treble into a blaring sound. They’re not the most colorful high frequencies, but if you like hearing simple clarity on ticking cymbals, then the Aeon Core will be a satisfying response for you.
The Dan Clark Audio Aeon Core is a closed-back planar headphone that stands out most for its spacious soundstage, organized imaging, and comfortable long-term fit. Its bass response might not satisfy listeners looking for heavy impact, but its neutral low-end, full midrange, and relaxed treble give it a smooth and controlled character. The Aeon Core is best suited for listeners who value separation, layering, and an immersive sense of space over a more energetic or bass-forward sound signature. As a more affordable alternative to Dan Clark’s upper-tier closed-back headphones, the Aeon Core offers a unique mix of premium design and planar performance that should appeal to fans of detailed, balanced listening.
  • Spacious soundstage for a closed-back headphone
  • Strong imaging and instrument separation
  • Comfortable fit for long listening sessions
  • Premium aluminum and wood design
  • Balanced, detailed midrange
  • Smooth, forgiving treble
  • Easier to drive than many planar headphones
  • Bass lacks strong impact
  • Upper mids have a slight veil
  • Not ideal for listeners who want a warmer or more energetic sound
The Dan Clark Audio Aeon Core will be available soon at Audio46.
