HomeReviewsBest Noise Cancelling HeadphonesStatus Audio GoldenSound Pro X Review: Audiophile Sound Meets True Wireless Convenience
The Status GoldenSound Pro X enters an increasingly competitive market for audiophile true wireless earbuds, where sound quality must coexist with everyday convenience. This special edition pairs Status Audio’s triple-driver architecture with custom tuning developed by respected audio reviewer GoldenSound, promising a more balanced and natural alternative to the heavily boosted signatures common among wireless models. With LDAC support, active noise cancellation, customizable EQ, multipoint connectivity, and a distinctive black-and-gold design, the Pro X appears well-equipped on paper. Let’s examine its comfort, functionality, wireless performance, and sound signature to determine whether it delivers a genuinely high-end listening experience.
  • Status GoldenSound Pro X True Wireless Earbuds
  • Wireless charging case
  • USB-C charging cable
  • 3 pairs of adjustable silicone ear tips (Small, Medium, Large)
  • User Manual
Status Audio GoldenSound Pro X single
If you’re not familiar with Status’ true wireless earphones, they have a unique square-shaped design that acts as their stem. Since this is the GoldenSound edition of the Pro X, the bottom portion of the stem is finished in gold against a matte black pattern. Gold and black always look great, so these earphones look particularly snazzy in a classy way. The main nozzle piece that actually goes in your ear has a small oval-shaped housing that fits just right.
The material is smooth, and the spout never feels intrusive at all. In fact, the GoldenSound Pro X is surprisingly small in general, so much so that how they appear on the box might mislead you into thinking they’re bigger than they are. Overall, these earbuds are very comfortable, with an incredibly stable fit. They don’t hang off your ears; they hold firm in place like a strong set of sports earbuds.
Status Audio GoldenSound Pro X case open
The Pro X GoldenSound uses a hybrid triple-driver configuration in each earbud, combining a large 12mm dynamic driver with two Knowles balanced-armature drivers. The dynamic driver handles the low frequencies, delivering deep bass with greater weight and control, while the dual balanced armatures reproduce vocals and high-frequency details with added clarity and precision. GoldenSound contributed the research, tuning, and final voicing, giving the system a more natural, balanced, and lifelike presentation. In terms of volume, these earphones can get loud, supplying you with plenty of volume to adjust comfortably.
Noise-canceling helps with this, and the Pro X GoldenSound has surprisingly good ANC. Top-end noise barely breaks through, and when music is playing, most of the environment is basically muted. Ambient mode does the exact opposite as expected, but it’s also very amplified. This is all controlled by the Status Hub app, or from the on-board touch sensors. The touch controls are very responsive, and I never had an issue with anything registering.
Playback controls are tight and have a short feedback time, while switching between ANC and ambient sound uses a physical button for more ease of use. The app also features customizable controls as an added benefit. The app also features custom EQ with five unique custom sound profiles, including GoldenSound’s own tuning. There are also options in the app to locate your earbuds in case you misplace them, including a special alarm or location setting like the Apple AirPods.
Status Audio GoldenSound Pro X case closed
The Pro X GoldenSound uses Bluetooth 5.3 and supports SBC, AAC, and LDAC codecs. Compatible Android devices can stream high-resolution audio at up to 24-bit/96kHz and 990kbps through LDAC, while Apple devices use AAC. Multipoint connectivity also allows the earbuds to remain paired with two devices simultaneously for easier switching between sources.
You’ll get up to eight hours of playback with active noise cancellation enabled and up to 32 hours of total listening time with the wireless charging case. Actual performance may vary depending on listening volume, ANC use, and codec selection, with LDAC playback potentially reducing battery life. The included USB-C cable provides an additional option for recharging the case.
Status Audio GoldenSound Pro X pair
With all of the GoldenSound Pro X’s EQ settings, the soundstage stays pretty much the same no matter what. This works out great for a true wireless earphone that’s more audiophile-centric, as the changes in timbre never affect the way spatial imaging is presented. You wouldn’t want it to, because the GoldenSound Pro X has a great soundstage for a true wireless earphone. The level of spatial precision and accuracy it displays shoots way beyond its price point, rivaling similar audiophile true wireless products like the Noble Audio FoKus Prestige Encore.
It’s a wide sound that spreads out past any perceived barriers for a more natural stereo environment. Sounds occurring in the left and right channels have a distinct identity that results in a very organized soundstage that never appears disjointed. Instruments are layered with good separation between them, placing your head as the only thing that is directly in the middle of the mix. This allows the soundstage to feel like it’s engulfing your head, even with a more standard stereo reference. The imaging isn’t exactly tall and scaled, but instruments are localized well enough to give the soundstage a sense of realism.
In terms of EQ, the best bass you’re going to get out of the GoldenSound Pro X is with GoldenSound’s custom tuning, or Status’s signature setting that you can control yourself. The GoldenSound tuning is the whole point of the new Pro X sound signature, but it’s not customizable. So, if you want the most bass possible with these earphones, then Status’ signature profile is your best bet. It gives you a neutral tone that you can increase for more sub-bass rumble, but no matter how much you adjust EQ, there’s usually something you need to sacrifice in terms of overall clarity.
The GoldenSound setting gives you a more refined low-end signature, with more finesse in physical bass notes. If you’re looking for something that’s more like most consumer true wireless earphones, use the Status custom EQ and boost to your heart’s content. However, if you’re looking for something more natural, GoldenSound’s tuning is the right move. This profile gives the bass a lot more depth, bringing out the sub-bass but with more subtle details. You get more of a throaty presentation that lets you feel the frequencies crawl around. It’s a grounded resposne with more structure. It might not punch as hard as other true wireless earphones, but this is still one of the more dynamic low ends you can find on a Bluetooth product.
The GoldenSound Pro X has one of the meatiest midrange sound profiles you can hear on true wireless earphones. Like the lows, the GoldenSound EQ setting is going to offer the most naturalistic timbre, but the other sound signatures are worth comparing. Sticking with GoldenSound’s profile, though, the midrange does a good job communicating sound elements with room and tonal clarity. They have a defined resolution that has low-mid warmth and upper-mid crispness. Nothing feels hollowed out in the fundamental frequencies, but transients do appear smoothed over. This gives the midrange good texture, but if you want to hear your instruments really pop, you may want to use Status’ “audiophile” setting. This will boost that fundamental range that you can make adjustments to yourself, but it will add a clearer strike to notes.
String plucks are more concise, but that low-mid warmth stays intact. You can also use the “Knowles” setting for even more naturalistic attack. The one setting I haven’t talked about is “vocal enhance,” which is designed to do exactly as it says. Vocals get a pretty aggressive push forward in the mix, revealing more accentuated voice tones that take more advantage of mid-treble frequencies. This whole area gets elevated and makes for a solidly underlined vocal tone.
If you like sibilant, crisp treble, stick with the vocal enhance or Knowles tunings. The Knowles tuning is especially bright, but not in a harsh way. It just has a steep shelf on it that adds some nice air to the frequencies. While it can be a bit shouty, this is the most high-end presence you’re going to get from the Pro X GoldenSound. The sound has more height, sizzle, and overall clarity compared to the other settings. GoldenSound’s treble has a clear mid-treble, then smooths itself out and dips down. You still get clicky hi-hats, but the tail is dulled and rolled off for a more digestible sound signature. You still get a bit of height, but the tone is definitely thinned.
The Status GoldenSound Pro X succeeds as an audiophile-focused true wireless earbud without sacrificing the features expected from a modern everyday model. Its expansive and precise soundstage is the biggest highlight, while the GoldenSound tuning delivers a grounded low end, full-bodied midrange, and smooth treble that favors natural tone over exaggerated excitement. Listeners who prefer more bass, brighter highs, or stronger vocal presence can also experiment with the additional EQ profiles, although some settings sound more refined than others.
Strong active noise cancellation, LDAC support, responsive controls, multipoint connectivity, and a secure fit make the Pro X practical beyond critical listening. Its treble can feel restrained with the GoldenSound profile, and more aggressive EQ adjustments may compromise overall clarity, but the earphones offer enough flexibility to suit several listening preferences. For anyone seeking detailed imaging, mature tuning, and premium functionality in a compact wireless package, the Status GoldenSound Pro X is an impressive option that competes comfortably with more expensive audiophile true wireless earbuds.
The Status Audio GoldenSound Pro X is available here.
