Dan Clark Audio has built a strong reputation for making closed-back planar headphones that feel compact, comfortable, and technically advanced. Two of its most interesting current models are the Aeon Core and the Noire X, both of which offer a closed-back planar design with different ideas of what a high-end listening experience should be. The Aeon Core focuses more on spaciousness, layering, and smoother tuning, while the Noire X brings more advanced acoustic technology and a livelier Harman-inspired sound signature.
Both headphones are made for serious listeners who want premium build quality and refined sound without jumping all the way to Dan Clark’s flagship models. However, their differences are clear once you start comparing their design, fit, and sound performance. Let’s break down the Aeon Core and Noire X to see which one is the better fit for your listening preferences.
| Aeon Core | Noire X |
The AEON Core and Noire X both carry Dan Clark Audio’s compact closed-back identity, but they approach style in different ways. The AEON Core feels like a more affordable take on the E3, using a combination of aluminum and wood that gives it a slightly more distinctive look than the usual AEON design. It is also one of the heavier headphones in Dan Clark’s lineup, but its low-clamp fit helps balance out the extra pressure.
Noire X sticks closer to the classic AEON Noire design language. It keeps the familiar ear-shaped cups, folding mechanism, nitinol suspension headband, and all-black aesthetic. The new reflective Gorilla Glass 3 earcups give it a sleeker, more modern appearance, while the updated self-tensioning headband helps distribute pressure more evenly. Comfort is strong on both headphones, but the Noire X has the edge for long-term wear. Its Alcantara synthetic suede earpads help reduce heat and moisture buildup, making it feel cooler over longer sessions. The AEON Core is still comfortable and easy to wear for extended listening, but its heavier frame is more noticeable.
The AEON Core uses a newly developed planar driver with a low 17-ohm impedance and around 97 dB/mW sensitivity. This makes it easier to drive than many planar magnetic headphones, which is useful for listeners who do not want to rely on a powerful desktop amplifier at all times. Its tuning follows a revised Harman-target approach, aiming for balance, accessibility, and planar-style clarity.
Noire X takes a more advanced technical approach. It uses a 62mm x 34mm single-ended planar magnetic driver and includes Dan Clark Audio’s Acoustic Metamaterial Tuning System, also known as AMTS. This technology has appeared in higher-end DCA headphones and is designed to smooth high frequencies, reduce standing waves, and create a more natural treble response. The Noire X is not impossible to drive, but its 94 dB SPL rating means it benefits from a dedicated DAC/amp. This is one of the biggest differences between the two headphones. The AEON Core is easier to drive and feels more approachable, while the Noire X uses more advanced acoustic design to deliver a more refined and energetic performance.
Soundstage is where the AEON Core makes its strongest impression. For a closed-back headphone, it sounds impressively wide and spacious. Instruments have a lot of room to breathe, and the stereo image feels cleanly organized. The AEON Core does a great job separating layers in complex arrangements, giving each element a clear place in the mix. Its sense of height and width makes it feel especially immersive for a closed-back planar.
The Noire X also has a strong closed-back soundstage, but it approaches space differently. It does not try to sound fully open, but its imaging and isolation work together to create a focused and believable sound environment. Its stage feels more controlled and intimate than the AEON Core, but its precision helps make up for that smaller sense of space. Listeners who want the widest and most immersive closed-back presentation will probably prefer the AEON Core. Those who want tighter imaging and a more polished sense of positioning may lean toward the Noire X.
The AEON Core has a neutral and restrained bass response. Its lows are clean and can show depth when the track has a strong bass instrument, but they do not hit with much force. Bass notes have some body, but the overall presentation stays soft and controlled. This makes the AEON Core better for listeners who want a lighter, more balanced low end rather than a punchy or bass-forward sound.
Noire X brings more energy to the bass. Its low end is still linear and uncolored, but it has more bounce, slam, and midbass presence than previous AEON-style headphones. It gives kick drums and bass lines more movement without sounding loose or overdone. The Noire X is also better at making bass feel exciting while still keeping it tight. This is a clear win for the Noire X if you want more impact. The AEON Core has a more relaxed low end, while the Noire X sounds more dynamic and engaging.
The AEON Core puts a lot of emphasis on the midrange. Its mids are full, balanced, and tactile, giving instruments a strong presence in the sound signature. However, they can also sound a bit dry, and the upper mids sometimes have a slight veil. This gives the AEON Core a smoother but less transparent midrange presentation.
Noire X has a more controlled and natural midrange. Vocals are clear without feeling pushed too far forward, and instruments separate cleanly. Even if its Harman-inspired tuning suggests a slight midrange dip, the Noire X does not come across as recessed. Instead, it sounds mature, clean, and well-managed. The AEON Core has more midrange body, while the Noire X has better clarity and refinement. If you like a fuller center image, the AEON Core works well. If you want vocals and instruments to sound cleaner and more controlled, the Noire X is the stronger performer.
The AEON Core has a forgiving treble response. Its highs are airy and smooth, adding height to the sound without becoming sharp or fatiguing. Cymbals and lighter details have clarity, but the treble is not especially colorful or vivid. This makes the AEON Core easy to listen to for long sessions, especially if you are sensitive to brighter headphones.
Noire X has the more impressive treble performance. Thanks to AMTS, its highs have sparkle, headroom, and resolution without sounding harsh or grainy. Cymbals, strings, and distorted textures come through with better definition, giving the Noire X a more detailed and lively top end. The AEON Core is better for listeners who want a softer, more relaxed treble. The Noire X is better for listeners who want more detail, air, and high-frequency excitement without fatigue.
Dan Clark Audio has two compelling closed-back planar headphones with the Aeon Core and Noire X. The Aeon Core stands out for its expansive soundstage and smooth, balanced character, making it a great option for listeners who want a more immersive closed-back experience. The Noire X, on the other hand, feels like the more advanced and complete headphone, offering stronger technical performance, better bass impact, and a more refined treble response. If your priority is soundstage and relaxed listening, the Aeon Core is easy to recommend. If you want the better overall performer and do not mind using a dedicated DAC/amp, the Noire X is the headphone to beat.
The Dan Clark Aeon Core and Noire X are available at Audio46.
