HomeReviewsBest Noise Cancelling HeadphonesNoble Audio FoKus Artemis Review: Is This Noble’s Best Wireless Headphone Yet?
Noble Audio has built its reputation on ambitious audiophile products, and the FoKus Artemis brings that philosophy to its most advanced wireless over-ear headphones yet. Featuring a rare three-driver hybrid system, high-resolution Bluetooth codecs, customizable ANC, and extensive sound personalization, the Artemis aims to deliver genuine high-end performance without sacrificing everyday convenience. At this level, however, technical ambition needs to translate into a polished listening experience. Let’s examine its design, features, battery life, soundstage, and overall sound quality to determine whether it stands among the best audiophile Bluetooth headphones available.
  • Noble Audio FoKus Artemis Headphones
  • USB-C Cable
  • 3.5mm Audio Cable
  • User Documentations
Noble Audio FoKus Artemis headband
This is Noble Audio’s most high-end wireless product yet, and it certainly looks the part. The Artemis is a proper upgrade from the Apollo and Apollo Pro, with not only bigger ear cups, but a more stylized silver plating to match its aluminum frame. It’s a lightweight build that’s a lot more flexible than it looks. The ear cups rotate to sit flat around your neck, which is also how they sit in the case. It reminds me of the Bowers and Wilkins PX8 design but less clampy and rigid. That brings me to the fit, which is really comfortable. The Artemis has these deep ear cups that give your ear a lot of space. The padding is very plush up against your ears, but the headband could be slightly better here. Otherwise, this is a circumaural fit that adds very little extra pressure to your head.
Noble Audio FoKus Artemis flat
The FoKus Artemis uses an uncommon three-driver hybrid configuration in each earcup, combining a dynamic driver, planar driver, and balanced-armature super tweeter. Each technology serves a different part of the presentation: the dynamic driver supplies bass weight and physical impact, the planar driver handles the midrange with speed and openness, and the balanced armature adds precision and extension to the upper frequencies. This approach aims to deliver the scale of a full-size headphone with greater separation, clarity, and detail across the frequency range.
The Artemis features user-adjustable active noise cancellation, allowing listeners to vary the amount of external sound reduction according to their environment. A six-microphone array supports the ANC system, while a dedicated transparency mode lets outside sounds pass through when greater situational awareness is needed. Together, these modes make it easy to move between focused private listening and conversations or public surroundings. ANC isn’t the focus of the FoKus Artemis, but what it gives you effectively quiets most obstructive noise without completly attenuaing them.
Through the Noble FoKus companion app, users can customize the Artemis with equalizer controls, spatial-audio options, and Audiodo sound personalization. Audiodo evaluates the listener’s hearing abilities to create an individualized audio profile, while the EQ provides further control over the headphone’s tuning. Personalized settings are stored directly on the Artemis, allowing them to remain active across connected devices without requiring the app to stay open.
The FoKus Artemis uses Bluetooth 6.0 and Qualcomm’s QCC3095 platform for modern wireless performance and reliable connectivity across phones, tablets, and computers. It supports high-resolution codecs including LDAC, aptX Adaptive, and aptX Lossless, while multipoint connectivity allows the headphones to remain paired with more than one device. For additional flexibility, the Artemis also supports digital audio over USB-C and conventional wired playback through a 3.5mm connection.
The FoKus Artemis targets more than 40 hours of playback with active noise cancellation disabled and over 35 hours with ANC engaged. Its 600mAh battery supports fast charging through USB-C and can reach a full charge in under 90 minutes. Unlike the permanently sealed batteries found in many wireless headphones, the Artemis features a fully user-replaceable battery, helping extend its usable lifespan.
Noble Audio FoKus Artemis side
With the Artemis, Noble has made its most spacious Bluetooth headphones. Everything about the soundstage feels open, wide, and articulate, organizing frequency bands and spacing them out for a higher level of positional identity than most wireless headphones. The left and right channels have a significant wingspan, and properly fill space without appearing too thin or stretched out. There are clear barriers in the soundstage, but the imaging offers so much dimension that you will barely notice them. The soundstage encompasses your head and wraps around it very effectively, all while reproducing an anchored stereo presentation. Panning information is very pointed and helps immerse the listener, especially with a very atmospheric track. Separation and height support this, giving instruments and vocals a ton of room to breathe in the mix. The Artimis has a big sound, and the soundstage/spatial imaging all help manage that for an expressive stereo environment.
In its default tuning, the Noble Artemis has a strong and enveloping bass impact, and it only gets more lively with EQ. With the lows and highs, I preferred to use the EQ curve to round out some of the tuning preferences I already like, and the Artimis responded very well. The sub-bass is the most expressive part of the lows here, rumbling with a growly vibration deep underneath the rest of the sound signature. It crawls up and down, giving bass performances an enticing drive that buzzes with detail.
With EQ, these qualities come more forward and can really dominate the frequency resposne. You might prefer to do that if you’re looking for some serious slam. What’s impressive is that the Artimis never loses its refinement or clarity when the bass tone is boosted. The resonance of the bass is controlled, and the timbre never changes, just the size. This results in a very rich tonality that sounds great whether or not you tweak certain parts of it.
Depending on your preferences, some areas of the midrange could use some tinkering with EQ. It’s a very flat resposne that can appear a bit dry at times when you’re just listening to it out of the box. The clarity is still great for a Bluetooth headphone, and instruments sound natural if just slightly undercut. Using a 10-band EQ or the EQ curve to make a small shelf will bring out the midrange tone considerably. Note strikes are more punctual, but it’s vocals that receive the clearest enhancement. You can get them to extend forward and place them right up in your face. This reveals some extraordinarily lifelike vocal performances, and the midrange gains a lusher tone in response. Instruments can be crisper and more accentuated in the upper-midrange, but if you’re not using EQ, the tone can feel a bit too plain.
If you EQ the treble like the mids, the results can be quite interesting. I prefer a shimmery high end, and with EQ, the Atremis can get there, but there’s a catch. You’ll get a considerable amount of sibilance from vocals, and although it’s never harsh or piercing, the frequencies will still have some bite to them. I happen to like some of this bite, so if you can get past that, the treble will have a lot to offer in terms of presence and height.
Otherwise, you can use EQ to adjust the high-end tone to your liking. No matter what, the high frequencies will feel tight and resolving, with a controlled ring that has a spark to it. High notes on a piano will clack down with a slightly bright tone, but taper off smoothly. When I go back to my EQ, the highs can get pretty intense, but it only helps to bring out detail rather than artificially brighten.
The Noble Audio FoKus Artemis is an ambitious wireless headphone with the spacious presentation, powerful bass, and technical detail expected from a high-end audiophile model. Its hybrid driver system creates an expansive and well-separated soundstage, while the responsive EQ makes it easy to bring more richness to the midrange or greater energy to the treble. The default tuning may sound slightly dry through the mids, and aggressive treble adjustments can introduce some sibilance, but the Artemis gives listeners enough control to shape its sound effectively.
Comfortable construction, high-resolution Bluetooth support, wired and USB-C playback, long battery life, and a user-replaceable battery further strengthen the overall package. ANC performance is useful rather than class-leading, but sound quality is clearly the priority. For listeners seeking a premium wireless headphone with deep bass, immersive imaging, and extensive customization, the Noble Audio FoKus Artemis offers a distinctive alternative to more conventional flagship Bluetooth models.
The Noble Audio FoKus Artemis is available at Audio46.
