HomeLatest NewsNOCS Release NS1100 Air True Wireless Earbuds
Delivering high-end sound products since 2009. They have gathered acclaim for their ability to create exceptionally well-crafted earphones, headphones, and speakers that meet the varied needs of today’s professional DJs and serious audiophiles. Their latest is a true wireless called the NS1100 Air, which goes for $150 and contains many different features.
FEATURES
Nocs Signature Sound
The NS1100 AIR custom-made 9.2 mm Graphene drivers are state-of-the-art – a true leap forward in sound technology – providing an optimal sound experience for the most discerning ears.
Hybrid Active Noise Cancellation
Hybrid ANC can suppress noise at a broad range of frequencies, adapt to and correct errors at speed. Surrounding noise is analyzed and anti-noise is created to eliminate the buzz around you.
Connectivity
Airoha (Bluetooth 5.0 dual-mode) provides seamless role switch performance which results in superior audio performance and noise-free, crystal clear voice. Experience 24-bit 192KHz HD Audio and Hi-resolution codec support (AAC).
Personal Sound By Audiodo
Audiodo Personal Sound, the epitome of sound personalization. Audio is optimized to suit each user’s individual hearing perception through the hearing calibration on the Nocs Design App.
Transparency Mode
Tap the earbud or use the Nocs Design App to activate transparency mode when you want to let the world in for a moment. Tap it again to return to your music.
Longer Battery Life
Up to 9 hours of non-stop listening. Up to 30 hours of battery life when buds and case are at 100% power, charging multiple times from case.
Download Nocs Design App
Use the app to control all features on iOS and Android devices.
SPECS
Bluetooth: 5.0
Sound Codecs: SBC, AAC codec
Driver Type: Electrodynamic, 9.2 mm diameter
Driver Sensitivity: 102 ±3dB
Impedance: 16 Ohm
Frequency Range: 20 – 20,000 Hz
IPX4 – nano-coating (dust and splash/sweat resistant).
64 Audio Ocean vs U12t 2025: Which High-End IEM Is Right...
64 Audio has built a reputation around in-ear monitors that reveal the finer details of a recording while keeping the music engaging. The Ocean...
Best Wired Headphones for iPhone Duo
