These wireless, music-playing earbuds function differently than your typical noise-cancelling headphones. Meet RippleBuds with noise blocking technology.
RippleBuds Noise Blocking Earbuds
RippleBuds seem to focus rather on drawing sound out of the noisy environment while simultaneously silencing the surrounding vicinity. With the use of an in-ear microphone, Team RippleBuds promise your voice can be heard in the noisiest of environments.
Based on the angle of the microphone inside the earbuds, the sound from your voice traveling through the Eustachian tube, through the ear drum, through the mic, and finally the speaker. Essentially, your voice is recognized from inside of the ear, rather than the outside. Working in tandem with their noise blocking technology, the position of the microphone is able to minimize ambient noise. As the wireless earbuds do so, the voice command function on your device should perform more efficiently.
As a pair of truly wireless earbuds, the bite-sized ear pieces can be used to listen to music and take calls. Thanks to the built-in voice technology, conversations should be crystal clear. The cable-less design means these buds are perfect to be used when traveling, driving, cleaning, etc. RippleBuds come with five different sized ear pads to ensure a comfortable and secure fit for all users. P.S. These noise blocking earphones are sweat-proof and the ear-pads are designed to be washable, making them perfect for fitness use.
RippleBuds should last for up to 5 hours off of one charge, which takes about 2 hours to achieve. The portable charging case holds up to 3 full recharges. In addition, these wire-free buds use Bluetooth 4.1 to pair with your smart devices over a distance of 30 feet. For those interested in the specs, these headphones reach a frequency response between 20-20,000 Hertz on an impedance of 16 ohms.
RippleBuds are available via Indiegogo at a discounted rate. Orders are expected to ship worldwide this month and again in October.
