HomeReviewsBest Noise Cancelling HeadphonesSony WF-1000XM6 Review: The New King of Noise Canceling Earbuds?
Sony’s 1000X series has long set the benchmark for premium true wireless noise-cancelling earbuds. With each new generation, expectations rise, not just for stronger ANC but for better sound quality, improved Bluetooth connectivity, and smarter features that justify the upgrade. The Sony WF-1000XM6 enters an increasingly competitive market promising its most advanced active noise cancellation yet, refined dynamic drivers, and expanded support for high-resolution wireless audio via LDAC and Bluetooth LE Audio.
Let’s break down everything that matters: design and comfort, Bluetooth 5.3 performance, battery life, and a full sound analysis covering soundstage, bass, mids, and highs. If you’re searching for the best noise-canceling earbuds in 2026 or wondering whether the XM6 improves meaningfully over its predecessors, this review will give you a detailed, experience-driven answer.
  • Earbuds
  • Charging case
  • USB Charging Cable
  • Four sizes of earbud tips
Sony WF-1000XM6 single
The past few WF-1000x models have all had different designs. I particularly liked the XM5’s slimmer, more ergonomic shape, but the XM6 surprisingly changes this. The housing is bigger, most likely to make room for all of the new microphones, but it sacrifices a more comfortable fit. Wearing the XM6 felt fine after a while, but they were always a little loose in my ear. Different ear tips might offer a more proper seal, but the stock foam tips don’t really do that.
Sony WF-1000XM6 case open
Each earbud houses refined dynamic drivers engineered for full-range sound with rich bass and clear highs. They are powered by Sony’s HD Noise Cancelling Processor QN3e, which works with multiple built-in microphones to detect and block ambient noise. Integrated DAC (digital-to-analog converter) and amplifier circuits help deliver detailed, high-resolution audio.
Nearly all WF-1000x earphone models will ensure the best noise-canceling you can experience over true wireless. The XM6 is the best yet, with even more advancements in their ANC tech. When I first put the earbuds in my ears, I set down the charging case and barely noticed that I did. Even close vibrations could be barely heard with the XM6’s ANC, which sums up how powerful its effect can be.
All of the common features that Sony usually provided for their 1000x sereis makes a return here, such as DSEE compression upscaling, 360 Reality Audio, and EQ. There are also new features like “Ingress” spatial sensors for AR gaming, and scene-based listening that allows the earbuds to sense different activities like running.
Sony WF-1000XM6 case closed
The Sony WF-1000XM6 earbuds use Bluetooth 5.3 for wireless connectivity, offering a stable and efficient connection with compatible devices. They support a broad range of Bluetooth audio codecs, including SBC, AAC, and Sony’s high-resolution LDAC, allowing wireless streaming of high-quality audio (especially on Android devices), as well as LC3 via Bluetooth LE Audio for more efficient transmission and potential latency improvements. The inclusion of Bluetooth LE Audio also enables advanced features like multipoint connectivity (connecting to two devices at once) and next-generation audio enhancements such as ultra-low latency and expanded broadcast/auracast capabilities with supported devices.
The Sony WF-1000XM6 earbuds offer up to roughly 8 hours of continuous playback on a single charge with ANC enabled, and around 24 hours of total listening time, including the charging case, meaning the case provides roughly an additional 16 hours of playback before needing a recharge.
Sony WF-1000XM6 pair
With each new version of the WF-1000x series, Sony makes significant improvements to how wide and spacious their true wireless earphones can sound. This is the most layered and articulate soundstage performance from any of their earbuds, presenting an expansive headspace without the need for spatial audio. Nothing about the XM6’s immersive imaging appears artificial. The stereo field has clear barriers, but it’s very natural, allowing each instrument to position itself gracefully with an impressive amount of space that separates each element accurately. I was most surprised by how little of the sound elements occupy the middle of the soundstage, highlighting left/right channel identity in a way that’s rare among true wireless earphones. There’s more dimension and height to this soundstage than any past model of the WF-1000x series, featuring inward depth that presents everything in an expansive bubble of sound.
I’ve had my personal issues with the bass response of Sony’s 1000x models, but they’ve gotten marginally better over the years. With the XM6’s, the bass is the cleanest yet, while still being pretty thick and boomy. There’s an effort made to reduce its resonance and concentrate the lows for a more impactful hit that doesn’t cause as much fog. It feels like it has more detail, but it still has that foundational texture that the 1000x series is known for in its bass. They aren’t quite resolving, but the clarity on display still feels like an upgrade.
Of course, you can EQ the bass to try and tune it more to your liking, but for me, the standard profile made enough of an impression to assess the lows as fairly as I could. You can always add and subtract gain from Sony’s wireless products, but the factory setting here really feels like the intended sound of the earphones more than any previous model.
This is the clearest midrange I’ve heard on a pair of Sony WF-1000x earphones. It makes a clear effort to showcase fuller instruments with more defined qualities that try to express more than smearing textures. You get a warm tone that pushes forward and allows for a roomy presentation that lets instruments breathe properly. As a result, the mids have more personality to them, featuring more accurate note strike and tonal accuracy. The upper-midrange even supports a more blaring midrange response, where you might want to use EQ to help smooth out some of its more expressive frequencies. However, you might also be subtracting from the best vocal resposne you’ll hear with the Sony 1000x series. They are super clear and feature the most resolving performance from the XM6.
Like the rest of the sound signature, the highs exhibit improvements from past models. The XM6 features the most prominent high frequencies of any pair of Sony earphones. They’re bright and have a good amount of energy that might actually be too aggressive for some listeners. It’s a bit of an overcorrection, but I never felt the highs were harsh enough to be uncomfortable. Using the “soft” preset should be enough, but I would suggest making more subtle adjustments.
The Sony WF-1000XM6 represents the boldest evolution yet in the 1000X lineup. Its active noise cancellation is nothing short of elite, immediately creating a vacuum-like silence that rivals or surpasses anything else in the true wireless category. Add in LDAC support, Bluetooth 5.3 with LE Audio and multipoint connectivity, and Sony’s familiar ecosystem of DSEE upscaling, 360 Reality Audio, and customizable EQ, and you’re looking at one of the most feature-complete wireless earbuds available.
Sonically, the XM6 takes meaningful strides forward. The soundstage is wider and more dimensional than any previous WF-1000X model, the bass is cleaner while retaining its signature weight, and the midrange clarity reaches a new level for the series. The treble, while more energetic and forward than before, adds detail and air that contribute to the earbuds’ most articulate presentation to date.
Fit may divide listeners due to the slightly larger housing, but if comfort works for you, the WF-1000XM6 delivers a powerful combination of immersive sound, cutting-edge ANC, and next-generation Bluetooth features. For anyone prioritizing premium wireless audio performance with top-tier noise canceling, the Sony WF-1000XM6 firmly earns its place among the best true wireless earbuds on the market.
  • Class-leading active noise cancellation
  • Wide, layered, and natural-sounding soundstage
  • Cleaner, more controlled bass than previous models
  • Clear, detailed midrange with excellent vocal presence
  • Bluetooth 5.3 with LE Audio and multipoint connectivity
  • Solid battery life (up to 8 hours with ANC, 24 hours total with case)
  • Larger housing may feel loose for some ears
  • Stock foam tips may not provide the best seal
  • Treble can sound slightly aggressive for sensitive listeners
The Sony WF-1000XM6 is available at Audio46.
