HomeReviewsHeadphone ReviewsXENNS Mangird Top Pro Review: Flagship Sound Without the Flagship Price?
Finding the right in-ear monitor can be challenging in a market filled with countless options competing for attention. With so many brands offering advanced features, premium materials, and ambitious designs, it takes more than a strong first impression to stand out. Listeners today expect comfort, quality construction, and a sound experience that feels worth the investment. The XENNS Mangird Top Pro enters this crowded space to appeal to enthusiasts who want a serious listening upgrade without moving into ultra-premium pricing. It arrives with the kind of presentation and feature set that suggests high expectations, but real value always comes down to everyday use and long-term enjoyment. Let’s take a closer look at the XENNS Mangird Top Pro to see how it performs where it matters most.
  • 1x Pair of XENNS Mangird Top Pro
  • 1x Detachable 0.78mm 2-pin cable with 3.5mm single-ended plug and 4.4mm balanced plug
  • 1x Premium leather carrying case
  • 3x Pairs of silicone ear tips (black, standard bore, sizes S/M/L)
  • 3x Pairs of silicone ear tips (gray/red core, narrow bore, sizes S/M/L)
  • 3x Pairs of white soft silicone ear tips (wide bore, sizes S/M/L)
XENNS Mangird Top Pro single
There are a lot of mid-budget Chi-Fi IEMs with similar designs, but the Mangird Top Pro is still very colorful and ergonomic in its design. Its faceplate design is very flashy with its gold script and glossy resin. It reminds me of the Empire Ears Odin, a super-premium IEM, so the comparison puts the Top Pro in pretty high praise. However, when holding the earphones in my hand, the price point starts to make more sense. The shells feel light but also hollow, and the ear cavity is transparent, revealing the inner components that make up the driver configuration. In terms of fit, the Top Pro has a good-sized nozzle and sits snugly in the ear with its stock tips. It works with the outline of your concha and holds itself still, making sure the earphones are comfortable and secure.
XENNS Mangird Top Pro cable
built around a 10-driver configuration that combines dual dynamic drivers for bass with multiple balanced armature drivers for mids, treble, and upper-air frequencies. A precision 4-way crossover manages how each driver group blends together, helping the Top Pro maintain cohesion while maximizing separation, speed, and clarity across the frequency range.
  • Frequency Response: 20Hz – 33kHz
  • Impedance: 16Ω
  • Sensitivity: 103dB ± 1dB
XENNS Mangird Top Pro pair
This is one of the widest and most open soundstages you can find in this price range. The Mangird Top Pro takes linear stereo imaging and expands it as far as possible, resulting in a flat presentation with significant scope. Left and right panning is stretched very far, but not in a way that thins the imaging. Nothing appears like it’s being pushed from a driver; rather, the sound emanates in a spacious stereo field where everything is displayed with a natural origin. Instruments are hyper-individualized and show fantastic positional accuracy.
The headspace feels open but still nailed down to never lose focus on precision. Layers are stacked effortlessly, as complex arrangements are communicated with separation and pinpoint localization. If the soundstage were just slightly more holographic, the Top Pro could have a frankly unreal amount of potential depth, but the linear stereo environment still finds a way to convey immersion. Everything feels static, and you might be more into something a bit more cavernous, but the Mangird Top Pro never stopped impressing me with how swiftly it translates exact pan movements.
The Mangird Top Pro is not a bass-heavy IEM, but it is not completely missing either. When the bass shows its true tonal potential, it’s tight and smooth. However, everything just seems a bit small, like the lows are too concentrated in one area. On the one hand, this resposne can provide a concise punch that gets in and gets out when it needs to. On the other hand, you don’t feel any extra ressonance or lift that can add extra power to the sound signature. Bass notes are very clean and have a natural timbre in the mix, just don’t expect any expressive depth from them. This leaves a lot of space unfilled, but the bass contributes to the overall frequency resposne with balance and clarity in its own way.
IEMs can sometimes have a textured midrange that emphasizes warmth and vocal performance. Other times, they can feature a resposne that treats the sound elements like real, physical objects that are being performed for you. The Mangird Top Pro is the latter, and it’s one of the richest I’ve heard in a while. Everything about the tone of the midrange exhibits exceptional transparency. It’s wonderfully natural but never relaxed. The attack on transients is super enticing, allowing notes to snap into the mix in a way that feels surgical.
Instruments have a proper shape and propel themselves forward with considerable drive. There’s a full spectrum of midrange properties on display, including a bit of warmth from the low mids, and some more biting upper-midrange artifacts. Nothing is left unrepresented. Vocals were the first thing that really stood out to me, as they show an incredible amount of resolve and closeness. This combination makes voices quite striking and expressive, conveying realism through crisp enunciation.
While some of the treble frequencies can appear a bit peaky, the Mangird Top Pro always balances itself with clarity and air. The highs have a lot of character and can extend quite far. They don’t match the midrange in energy, but they’re pretty close in pure detail. They’re lively enough to increase the height of the sound signature, letting the upper-high-end tail off naturally with a touch of sizzle. Everything is very clear, and even has a sparkly texture in some areas, but it also has the potential to feel pretty bright in others. It’s nothing I would consider harsh, but you can definitely feel the treble heat up as certain tracks increase their energy.
The XENNS Mangird Top Pro proves itself to be a highly capable in-ear monitor that focuses on precision, openness, and musical transparency rather than exaggerated coloration. Its greatest strengths lie in its impressively wide soundstage, articulate midrange, and detailed treble response, giving it a presentation that feels refined and technically accomplished for the price. Vocals sound vivid, instruments are sharply defined, and stereo imaging remains one of the most impressive qualities this IEM brings to the table.
Listeners searching for thunderous bass or a warmer, smoother tuning may want to explore other options, but those who value clarity, separation, and an expansive listening experience will find a lot to admire here. In a crowded field of mid-priced hybrid IEMs, the XENNS Mangird Top Pro successfully distinguishes itself as a serious contender for enthusiasts who want flagship-inspired performance without stepping into summit-fi pricing.
The XENNS Mangird Top Pro is available at Audio46.
