HomeReviewsComparison ReviewsXENNS Mangird Top Pro vs Kiwi Ears x HBB Punch Comparison Review
Hybrid IEMs have become some of the most exciting options in the mid-range market, especially for listeners who want more driver variety, stronger technical performance, and bolder tuning choices without spending flagship-level money. XENNS and Kiwi Ears both have strong reputations in this space, but the Mangird Top Pro and Kiwi Ears x HBB Punch take very different approaches to what a modern hybrid IEM should sound like.
The XENNS Mangird Top Pro aims for a more refined, spacious, and detail-focused presentation, while the Kiwi Ears x HBB Punch goes for a fuller, bass-driven sound with a fun and energetic identity. Both have their own strengths, but they appeal to very different listeners. In this comparison review, we’ll take a closer look at how they stack up in design, comfort, soundstage, bass, mids, highs, and overall value.
Mangird Top Pro Punch
  • Pair of XENNS Mangird Top Pro
  • Detachable 0.78mm 2-pin cable with 3.5mm single-ended plug and 4.4mm balanced plug
  • Premium leather carrying case
  • 3x Pairs of silicone ear tips (black, standard bore, sizes S/M/L)
  • 3x Pairs of silicone ear tips (gray/red core, narrow bore, sizes S/M/L)
  • 3x Pairs of white soft silicone ear tips (wide bore, sizes S/M/L)
  • Kiwi Ears x HBB Punch IEMs
  • Zipper Case
  • 2-pin cable with 3.5mm or 4.4mm connector
  • S/M/L silicone ear tips
  • 2 pairs of replaceable filters
  • User manual
Both IEMs are comfortable, but they communicate their personalities differently. Mangird Top Pro looks more refined and flashy, while Punch feels more fun and casual. For pure visual flair, the Top Pro has the edge, but the Punch still delivers a stylish and secure fit. The XENNS Mangird Top Pro has a flashier, more premium-looking shell, with glossy resin, gold accents, and a colorful faceplate design that gives it a more high-end appearance. Its transparent cavity also lets you see the internal driver configuration, adding to its technical appeal. In the hand, though, the shells feel lighter and a bit more hollow than the design might suggest. The Kiwi Ears x HBB Punch has a more playful look, using a purple-and-black shell design that fits well with Kiwi Ears’ usual visual style. Its resin chassis feels familiar for a Chi-Fi IEM, but the shape is ergonomic and easy to wear. The Punch sits securely and comfortably, making it a good option for longer listening sessions.
On paper, the Mangird Top Pro is the more complex IEM, with a larger driver count and a more technically ambitious crossover. The Punch is less about driver quantity and more about a specific tuning goal: bass power, warmth, and musical engagement. The XENNS Mangird Top Pro uses a 10-driver hybrid configuration, combining dual dynamic drivers for bass with multiple balanced-armature drivers for the mids, treble, and upper-air frequencies. A 4-way crossover helps manage separation and cohesion across the frequency range. This design gives the Top Pro a more technical foundation, especially for listeners who prioritize clarity, layering, and stereo imaging.
The Kiwi Ears x HBB Punch uses a five-driver hybrid setup with one 10mm composite dynamic driver, two Knowles balanced armature drivers, and two Sonion electrostatic drivers per side. Its tuning focuses heavily on sub-bass impact, with the dynamic driver providing a strong low-end foundation while the BA and EST drivers handle the rest of the frequency range.
Mangird Top Pro immediately stands out for its spacious stereo image. Its soundstage is wide, open, and impressively precise for its price range. Left and right panning stretches far without thinning out the imaging, and instruments appear with clear positional accuracy. It is not the most holographic or cavernous presentation, but it has a clean, linear sense of space that makes complex mixes feel organized and easy to follow.
Punch also provides good width and accurate placement, but its stage feels more limited in height and overall headspace. It can separate instruments well and create enough room between layers, but it does not open up in the same way as the Mangird Top Pro. Instead, its imaging feels flatter and more grounded, which still works well for placement but lacks the same expansive quality. For soundstage, the Mangird Top Pro is the clear winner. It sounds more open, more precise, and more technically impressive. Punch performs well enough, but it does not reach the same level of scale or spatial refinement.
Bass is where these two IEMs separate themselves the most. Mangird Top Pro has a cleaner and tighter low-end response, but it is not a bass-heavy IEM. Its bass notes are smooth, controlled, and natural, but they do not offer a ton of extra weight or resonance. You get punch and definition, but not much in the way of depth or physical slam.
Punch lives up to its name with a much stronger bass presence. Its sub-bass emphasis gives the sound a deeper foundation, and the low-end has a more physical sense of movement. Bass notes feel richer, more textured, and more exciting, especially for genres that benefit from impact and body. It can be a bit much for listeners who prefer a balanced signature, but for bass fans, this is the main reason to choose the Punch. Kiwi Ears x HBB Punch easily wins for bass quantity and excitement. Mangird Top Pro has the cleaner and more controlled bass response, but Punch has the stronger personality and more satisfying low-end force.
Mangird Top Pro delivers one of its best performances in the midrange. It sounds transparent, articulate, and highly resolved, with instruments appearing cleanly shaped and sharply defined. Vocals have excellent closeness and expression, giving the midrange a crisp and realistic quality. There is some warmth in the low mids, but the overall character stays clear, balanced, and highly detailed.
Punch has a warmer and softer midrange. Its mids are not buried under the bass, which is important for a bass-forward IEM, but they lack the same transient snap or definition as the Mangird Top Pro. Notes arrive with a smoother edge, and while there is good body and warmth, instruments do not always cut through the mix with the same identity. Listeners who want clarity, vocal detail, and instrumental separation will likely prefer the Mangird Top Pro. Those who want a fuller and warmer midrange that supports a bass-heavy sound will enjoy the Punch more. Still, for overall midrange performance, the Top Pro is more refined and expressive.
Treble on the Mangird Top Pro is clear, airy, and detailed, with enough sparkle to give the sound signature extra height. Some tracks can bring out a bit of peakiness, and listeners sensitive to brightness may notice the treble heating up at times. Even so, the highs contribute a lot to the Top Pro’s sense of clarity and openness.
Punch takes a more relaxed approach to treble. Its highs are less crisp and less sparkly, which makes it easier to listen to if you dislike brightness, but it also means the top-end can feel a little dull. There is enough treble presence to prevent the sound from becoming muffled, but the roll-off keeps it from feeling as lively or detailed as the Mangird Top Pro. Mangird Top Pro has the stronger treble performance for detail, air, and extension. Punch is smoother and safer, but it lacks the same energy and definition.
The XENNS Mangird Top Pro and Kiwi Ears x HBB Punch are both strong hybrid IEMs, but they serve different purposes. The Mangird Top Pro is the better choice for listeners who want precision, soundstage, and detail. It offers a more refined and spacious presentation that feels closer to a serious audiophile tuning. Kiwi Ears x HBB Punch is the more energetic and bass-focused option. It does not match the Top Pro in treble clarity or midrange definition, but it delivers a more physical and fun low-end response that makes it stand out. For overall technical performance, the XENNS Mangird Top Pro wins. For bass impact and a warmer, more entertaining sound, the Kiwi Ears x HBB Punch is the better pick.
The XENNS Mangird Top Pro and the Kiwi Ears x HBB Punch are available at Audio46 and Linsoul.
