HomeReviewsComparison ReviewsBeyerdynamic DT 30 IE vs Sennheiser IE 200 Comparison Review
The budget IEM market has become more competitive than ever, especially for listeners who want something more refined than a standard pair of earphones. Two models that stand out in this space are the Beyerdynamic DT 30 IE and the Sennheiser IE 200. Both come from major audio brands with strong reputations, but they approach sound and use cases a little differently.
The Beyerdynamic DT 30 IE feels more like a compact professional monitor made for musicians, stage performers, and listeners who want a dependable reference sound. The Sennheiser IE 200 leans more toward the audiophile side, offering a natural, engaging response that makes it one of the stronger budget-fi IEMs in its class. Here is how they compare.
DT 30 IE IE 200
  • DT 30 IE earphones
  • 1.4m cable with MMCX connector and 3-pole jack plug
  • S, M, L silicone eartips
  • S, M, L foam eartips
  • One pair of cerumen filters
  • Carrying Case
  • IE 200 Earphones
  • Braided Cable with MMCX Connectors and 3.5mm Plug
  • Silicone and Memory Foam Sets (S, M, L)
  • Pouch
  • Safety guide
Beyerdynamic DT 30 IE vs Sennheiser IE 200 single
The DT 30 IE has a more distinct visual identity compared to the IE 200. Its white translucent shell gives it a cool retro look, while still keeping the compact, professional shape Beyerdynamic IEMs are known for. It is small, lightweight, and easy to wear for long periods, which makes sense for an IEM that can work on stage or in the studio.
Sennheiser’s IE 200 takes a more understated approach. Its all-black shell is not flashy, but it follows the same general design language as the IE 600 and IE 900. That gives it a familiar, ergonomic shape that sits comfortably in the ear. It feels less unique than the DT 30 IE visually, but its fit is one of its strongest qualities. Both IEMs are comfortable, but the DT 30 IE feels a little more durable and practical thanks to its flexible Kevlar-reinforced cable. The IE 200 is lighter and more minimal, which some listeners may prefer for casual daily use.
Beyerdynamic DT 30 IE vs Sennheiser IE 200 cables
The Beyerdynamic DT 30 IE uses a single dynamic driver designed for full-range stage monitoring. This gives it a coherent response, with bass, mids, and treble all coming from one transducer rather than being separated across multiple drivers. Its 18-ohm impedance and high SPL rating make it a practical choice for monitoring setups.
The Sennheiser IE 200 also uses a single dynamic driver, specifically Sennheiser’s 7mm True Response transducer. This driver is designed for low distortion and a balanced response, with diffuse-field equalization helping shape its more natural sound signature. Although its impedance is also 18 ohms, the IE 200 can feel a little more power-hungry than expected, meaning it benefits from a decent dongle DAC or source. Both IEMs use dynamic drivers, but their goals are different. The DT 30 IE is more of a musician’s tool, while the IE 200 aims for accessible audiophile listening.
Beyerdynamic DT 30 IE vs Sennheiser IE 200 pair
The DT 30 IE presents a controlled, accurate soundstage that feels built for monitoring. It does not try to sound huge or overly spacious, but it gives you strong positional accuracy. Sound elements are easy to localize, and the imaging feels direct and organized. Its staging can feel a little consolidated, but it works well for reference listening. The IE 200 has one of the more natural soundstages in its price range. It is not extremely wide or deep, but it gives each performance a convincing sense of space. The imaging is accurate, and the presentation feels balanced rather than exaggerated. Compared to the DT 30 IE, the IE 200 sounds a bit more immersive and musical, while the Beyerdynamic feels more focused and strict. For monitoring, the DT 30 IE has the edge. For everyday listening and immersion, the IE 200 feels more engaging.
Beyerdynamic gives the DT 30 IE a surprisingly impactful bass response. It has good sub-bass presence, adding a grounded foundation without overwhelming the rest of the mix. The bass is punchy, controlled, and detailed, making it useful for both stage monitoring and casual listening. It has more body than you might expect from a reference-style IEM.
The IE 200 also has a satisfying low end, but it carries a warmer and slightly more rounded character. It does not reach especially deep, but it gives bass notes enough thickness and punch to feel lively. Its low end is more about warmth and musicality than strict monitoring.The DT 30 IE has the more controlled and reference-friendly bass, while the IE 200 has the warmer and more inviting tone.
Midrange is where both IEMs perform well, but they express detail differently. The DT 30 IE keeps its mids even and natural, without adding too much warmth or upper-mid sharpness. Instruments and vocals come through clearly, and acoustic performances benefit from its realistic sense of space. It sounds cohesive and balanced, which is exactly what you want from a monitor-style IEM.
Sennheiser’s IE 200 gives the midrange a bit more personality. Its low-mids have more body, giving instruments some added weight, while vocals and brighter acoustic textures still come through with strong clarity. It has a detailed, expressive midrange that works especially well for acoustic guitars, piano, and vocal-focused tracks. The DT 30 IE is flatter and more neutral in the mids. The IE 200 is more textured and emotionally engaging.
Beyerdynamic is known for bright treble, but the DT 30 IE feels more forgiving than some of the brand’s classic tunings. There is still a clear ring to the highs, with enough air and sizzle to keep the sound lively, but it avoids becoming too sharp. Listeners sensitive to treble may still notice Beyerdynamic’s signature brightness, but it is handled well here.
The IE 200 has a more intense treble presentation. Its highs are crisp and concentrated, giving the sound a strong sense of detail and energy. However, sibilant textures can become more noticeable, especially at higher volumes. It is not harsh in a traditional sense, but its treble has more bite than the DT 30 IE. The DT 30 IE has the more forgiving high end, while the IE 200 has the more energetic and revealing treble.
Both the Beyerdynamic DT 30 IE and Sennheiser IE 200 are strong budget IEMs, but they serve different listeners. The DT 30 IE is more practical, durable, and reference-focused, making it a great option for musicians or anyone who wants a compact monitoring IEM. The IE 200 is more musical and expressive, giving audiophiles a more engaging listen with impressive resolution for its price. If you need a reliable IEM for performance and monitoring, go with the Beyerdynamic DT 30 IE. If you want one of the best budget IEMs for immersive music listening, the Sennheiser IE 200 is still hard to beat.
The Beyerdynamic DT 30 IE and the Sennheiser IE 200 are available at Audio46.
