HomeReviewsBest Noise Cancelling HeadphonesSony 1000X THE COLLEXION vs WH-1000XM6: Is Sony’s Luxury Headphone Worth the...
Sony 1000X THE COLLEXION vs WH-1000XM6: Is Sony’s Luxury Headphone Worth the Upgrade?
Sony’s 1000X series has established itself as one of the most recognizable names in wireless noise-canceling headphones. The WH-1000XM6 continues that legacy with a refined design, extensive smart features, and some of the strongest ANC available. The 1000X THE COLLEXION takes a different approach, transforming Sony’s familiar wireless platform into a more luxurious headphone with upgraded materials and a bespoke driver system.
Both models share much of the same underlying Sony DNA, but they target different listeners. Does the Collexion provide a meaningful improvement over the XM6, or does the more affordable flagship remain the stronger overall choice? This Sony 1000X THE COLLEXION vs WH-1000XM6 comparison examines their design, features, Bluetooth performance, battery life, and sound quality.
Sony 1000X THE COLLEXION vs WH-1000XM6 headband
The WH-1000XM6 follows the lightweight, practical design language introduced with the XM5, while making several useful refinements. Its construction feels tighter and sturdier, with ear cups that remain securely positioned instead of swiveling loosely. A modified headband creates a snug fit, and the return of a folding hinge makes the XM6 easier to pack for commuting and travel.
The Collexion has a more luxurious appearance. Instead of relying primarily on plastic, it incorporates stainless-steel accents and vegan leather around the ear cups. Its roomy interior and angled drivers provide plenty of space around the ears, helping the headphone maintain the comfortable ergonomics associated with the 1000X series. Both models are comfortable enough for extended listening, but their priorities are different. The XM6 is lighter, more portable, and better suited to everyday travel. The Collexion feels more substantial and visually refined, giving it the clear advantage in materials and presentation.
Sony 1000X THE COLLEXION vs WH-1000XM6 stacked
Sony equips both headphones with its QN3 noise-canceling processor. The XM6 produces an exceptionally quiet listening environment, significantly reducing fans, crowd noise, and nearby conversations. Voices can still be faintly audible, but they become difficult to understand. The Collexion expands this system by combining the QN3 and V3 processors with 12 microphones. Its noise cancellation gets even closer to muting outside sound, including a greater portion of nearby voices. A six-microphone AI beamforming system also helps improve voice clarity during calls.
Touch controls are responsive on both headphones. The XM6 makes gestures more reliable than previous Sony models, with precise sliding volume adjustments and an effective Talk-Thru shortcut. It also includes wear detection for automatically pausing and resuming playback. The Collexion retains Sony’s familiar gesture system with similarly accurate operation. Sony’s Sound Connect app provides EQ controls, DSEE processing, spatial audio, and other listening adjustments for both models. The XM6 offers more spatial audio modes, while the Collexion includes the same fundamental customization expected from Sony’s flagship lineup. The XM6 already provides excellent ANC and controls, but the Collexion’s additional microphones and processing give it the edge for pure noise isolation.
The WH-1000XM6 uses Bluetooth 5.3 with support for SBC, AAC, LDAC, and LC3. Its connection is stable, pairing is fast, and multipoint allows the headphone to remain connected to two devices simultaneously. The Collexion moves to Bluetooth 6.0 while offering the same essential codec selection, including LDAC for higher-resolution wireless playback and LC3 through LE Audio. It also supports multipoint connectivity and provides an effective wireless range of approximately 10 meters. Bluetooth 6.0 makes the Collexion the more technologically current headphone. In everyday use, however, both deliver the important Sony features most listeners will need. LDAC, multipoint, and reliable connectivity are available regardless of which model you choose.
Battery performance is one area where the WH-1000XM6 has a decisive advantage. It provides up to 30 hours of playback with noise cancellation activated and as much as 40 hours with ANC turned off. While these numbers are no longer exceptional compared to some competitors, they are enough for several days of regular use. The Collexion reaches up to 24 hours with ANC and 32 hours without it. A five-minute quick charge supplies approximately 90 minutes of additional playback, but its total endurance is still shorter than the XM6. Neither headphone leads the wireless market in battery life, but the XM6 is the more dependable choice for long trips and frequent commuting.
Sony 1000X THE COLLEXION vs WH-1000XM6 side
The WH-1000XM6 features one of the most spacious stereo presentations found in Sony’s mainstream 1000X lineup. Its soundstage is wider and taller than previous models, with more recognizable left-to-right separation and improved movement between channels. The image remains mostly contained inside the head, but its larger scale brings the XM6 closer to the presentation of a wired closed-back headphone. Sony’s Cinema spatial mode attempts to move the sound outside the headphones. This can add a more dome-like quality that works particularly well with film scores, although it reduces some of the separation found in the standard stereo presentation.
The Collexion provides a wider and more naturally organized soundstage. Its stereo imaging offers clearer separation, better scale, and more accurate positioning without needing additional spatial processing. The presentation is still relatively linear, but it surrounds the listener more convincingly than the XM6. Spatial audio is less successful on the Collexion. Activating it squeezes instruments together and makes the presentation feel more artificial. Fortunately, its standard stereo image is spacious enough that spatial processing rarely feels necessary.
Bass is the dominant feature of both sound signatures. The XM6 delivers a thick, punchy low end, but its factory tuning can sound muffled and lacking in definition. Sony’s EQ tools are important here. With the right adjustments, the bass becomes more balanced while retaining the weight and impact expected from the 1000X series.
The Collexion pushes this presentation even further. Its bass hits with greater force and extends deeper into the sub-bass, giving electronic music, hip-hop, and cinematic tracks a powerful foundation. There is slightly more clarity than on the XM6, along with a richer sense of texture and body. However, the Collexion does not completely resolve Sony’s bass bloat. Resonance still bleeds into surrounding frequencies, obscuring some finer details and making the low end feel less controlled than it should at this level. The Collexion has the bigger and more visceral bass response. Listeners seeking a more manageable low end may prefer the XM6, particularly after using EQ.
The XM6 makes some progress in midrange clarity, but this area remains recessed and veiled. Instruments can struggle to develop clean timbral characteristics through the low-mid haze. Plucked notes and sharper transients cut through with more definition than they did on previous 1000X models, and EQ can give vocals a more lively presence. Vocals are one of the Collexion’s most noticeable improvements. They sound clearer, more elevated, and better articulated, benefiting from additional upper-midrange presence. Unfortunately, the rest of the midrange remains scooped. Low-mid instruments can sound cloudy and blurred, producing a distinctly V-shaped signature. The Collexion does a better job highlighting voices, but neither headphone offers a particularly natural or full-bodied midrange. Both benefit significantly from EQ.
The XM6 has the more approachable treble response. Its highs are soft but sufficiently present, with a clean click and a light shimmer around cymbals. This is the most transparent region of the XM6’s sound signature, and listeners who want additional crispness can raise it through EQ. Treble on the Collexion is more colorful but less consistent. It can produce a sharp glare and satisfying bite, yet its steep roll-off prevents notes from ringing out naturally. Some passages sound crisp, while others feel hollow or abruptly cut short. Although the Collexion can be more energetic, the XM6 provides a smoother and more coherent treble presentation.
The Sony 1000X THE COLLEXION is the more luxurious headphone. Its stainless-steel accents, vegan leather, spacious ear cups, Bluetooth 6.0 connectivity, stronger noise isolation, deeper bass, clearer vocals, and wider stereo image all distinguish it from Sony’s mainstream flagship. Its sonic improvements are not comprehensive, though. The bass remains bloated, the midrange is still recessed, and the treble rolls off too abruptly. These limitations make it difficult to view the Collexion as a major audiophile upgrade, especially for listeners expecting a balanced or highly resolving sound.
The Sony WH-1000XM6 remains the better value and the more practical everyday headphone. It has longer battery life, a foldable design, excellent ANC, extensive app features, and a smoother treble response. Its factory tuning also has issues, but Sony’s EQ tools make it adaptable enough for a wide range of listeners. Choose the Sony 1000X THE COLLEXION if premium materials, maximum noise cancellation, powerful sub-bass, and a wider soundstage are your priorities. Choose the WH-1000XM6 if you want the more versatile, portable, and cost-effective version of Sony’s flagship wireless experience.
The Sony WH-1000XM6 and the 1000X COLLEXION are available at Audio46.
