HomeReviewsBest Noise Cancelling HeadphonesFinal Audio UX5000 Review: Affordable ANC Headphones with Audiophile Tuning
Final Audio has built a strong reputation for bringing a more sound-focused approach to its wireless headphones, and the UX5000 continues that direction. It enters a competitive field of Bluetooth noise-canceling headphones with a mix of modern features, long battery life, and a design that feels more refined than most affordable options. Let’s look at how its build, comfort, functionality, Bluetooth performance, and sound quality come together to see where it stands among today’s wireless ANC headphones.
  • UX5000 headphones
  • Zipper case
  • 3.5mm auxiliary cable
  • User manual
Final Audio UX5000 headband
The UX5000’s build is the perfect evolution of Final Audio’s over-ear wireless design. It keeps the series’ Shibo finish with a more refined framework that makes it stand out among the pack of other affordable wireless headphones. They even have these magnetic, removable pads that make them easy to replace, which puts the UX5000 another step above. However, these pads are small, and the headband has some pinch to it. The cups are also not very deep, but they do have nice interior padding as well as exterior, so you do get some basic comfort. Overall, the comfort really depends on the size of your ears and how long you’re able to wear them before feeling the pressure.
Final Audio UX5000 above
The UX5000 is built around a 40mm large-diameter dynamic driver, with acoustic tuning informed by Final’s flagship A10000 earphone development. For wired listening, the included cable allows the headphones to maintain Final’s DSP-based tuning while reducing latency for music production, video editing, and gaming. These drivers project a sizable output that leaves you with a respectable amount of headroom for volume adjustment, so you’re not blasting the headphones at their highest possible volume consistently.
Noise canceling also helps with this, and for the price, it’s as strong as it needs to be. Most distractions are muffled or outright muted. The ambient mode is actually surprisingly loud, so much so that switching back and forth can be quite jarring. With the downloadable app, you get a 10-band EQ but no other sound personalization options, which is a bit dissapointing considering the technology of the Tonalite. I would like to see that brought to the UX series in the future.
The Final Audio UX5000 uses Bluetooth 5.4 with Qualcomm’s QCC3095 SoC, giving it a modern wireless platform with strong codec support. It supports SBC and AAC for standard device compatibility, along with aptX, aptX HD, aptX Adaptive, and LDAC for higher-quality Bluetooth playback on supported devices. Multipoint connectivity also lets the UX5000 stay connected to two devices at once, making it easier to switch between a phone, laptop, tablet, or portable player without constantly re-connecting. Combined with its app-based controls and DSP processing, the UX5000’s Bluetooth features are built to balance everyday convenience with higher-resolution wireless listening.
The Final Audio UX5000 offers strong battery performance for long listening sessions, with up to 45 hours of playback when active noise cancellation is turned on and up to 65 hours with noise cancellation turned off. This gives the UX5000 enough endurance for commuting, travel, work, and extended wireless listening without needing frequent recharges. It also reaches a full charge in about two hours, making it easy to quickly get back to extended use. Final also highlights the UX5000’s serviceable battery design, which helps give the headphones a more practical long-term lifespan compared to many sealed wireless models.
Final Audio UX5000 side
In terms of width and sound placement, the UX5000 is very good compared to what you usually get in this price range. The UX5000 shows a lot of positional integrity, with more separation than most affordable over-ear Bluetooth headphones should be capable of. Instruments are displayed with good spatial identity and stack on top of each other very nicely. You can discern layers of sound without any fog, as sound elements are localized clearly throughout the stereo field. Everything still sounds pretty upfront, but the imaging is never too flat or linear.
You might be disappointed by the UX5000’s lack of low-end weight, but the bass still has a lot to offer. Its tone might not be thick and rumbly, but it has a very clear shape. The bass frequencies are clear and present enough to showcase bass notes as fully whole, establishing an efficient foundation that could just use the slightest amount of lift to truly pop. Otherwise, the bass is balanced and enjoyably neutral in timbre. Finding detail in bass guitar strums is the most fun you’re going to get out of the UX5000’s lows, and that’s totally acceptable for this kind of wireless headphone.
This is certainly the best midrange profile that Final Audio has given to their UX series headphones. Everything about it is simply nice and elegantly displayed. There’s clarity with its level of energy and vocal forwardness, and the instruments have roominess that allows for more individuality when it comes to how fully they’re presented. Notes don’t have a lot of precision, and the transients can be quite slow, but on the surface, the tone is lively and organized well.
The treble is soft and smooth, yet still maintains a strong presence in the sound signature. There’s a glimmer to the timbre that allows the highs to really make an impression without being too bright. You actually get a sense of realism with its detail retrieval, as the frequencies ring out naturally and roll off in a way that’s not too abrupt. All of that, combined with some light air and height thrown in, yields a treble that feels eloquently tuned.
The Final Audio UX5000 is a strong step forward for Final’s wireless headphone lineup, offering a thoughtful mix of modern features and refined sound tuning. Its Bluetooth 5.4 platform, LDAC and aptX Adaptive support, multipoint connection, app-based EQ, active noise canceling, and excellent battery life make it a capable everyday headphone for commuting, work, travel, and casual listening. The serviceable battery design and replaceable magnetic ear pads also help give the UX5000 a practical advantage over many similarly priced wireless headphones.
Sound is where the UX5000 makes its best case. Its bass may not satisfy listeners looking for heavy slam, but it stays clean, balanced, and detailed. The midrange is lively and well-organized, while the treble brings smoothness, air, and a natural sense of detail without becoming sharp. Combined with its surprisingly capable soundstage and imaging, the UX5000 delivers a more spacious and composed presentation than many affordable Bluetooth noise-canceling headphones. Comfort may depend on ear size and fit preference, but for listeners who want a wireless ANC headphone with strong codec support, long battery life, and a more mature sound profile, the Final Audio UX5000 is an easy model to recommend.
Pros  Cons
  • Spacious soundstage
  • Clear mids and smooth treble
  • Refined design and Shibo finish
  • Replaceable magnetic ear pads
  • Strong Bluetooth codec support
  • Multipoint connectivity
  • Long battery life
  • Effective ANC for the price
  • Ear pads may feel small
  • Not a ton of sound personalization options
The Final Audio UX5000 is available at Audio46.
