HomeReviewsAudiophile ReviewsThieaudio Valhalla vs 64 Audio U12t Comparison Review
Once you get into the $2,000 IEM range, expectations start to change. Listeners are no longer just looking for strong detail or clean tuning; they want a product that can justify flagship pricing through build, comfort, technical performance, and long-term listening value. Thieaudio Valhalla and 64 Audio U12t both sit in this elite category, but they approach high-end sound in very different ways. Valhalla represents THIEAUDIO’s most ambitious driver-packed flagship, while U12t remains one of 64 Audio’s most trusted reference IEMs. So which one offers the stronger flagship experience?
U12t (2025) Valhalla
  • U12t Universal In-Ear Monitors
  • Carry Case
  • TrueFidelity Foam Ear Tips (S,M,L)
  • SpinFit Silicone Ear Tips (S,M,L)
  • Silicone Ear Tips (S,M,L)
  • 3.5 mm Silver Premium Cable
  • 4.4 mm Silver Cable
  • Shirt Clip
  • Cleaning Tool
  • Cleaning Cloth
  • Round Sticker
  • Apex Modules (m20, m15, m12, mX)
  • Valhalla In-Ear Monitors
  • THIEAUDIO EliteNoir Cable (3.5mm single-ended and 4.4mm balanced)
  • Cleaning cloth
  • 1 set of S/M/L silicone tips
  • 1 set of S/M/L foam tips
  • 2 sets of replaceable filters
As a visual statement, Valhalla feels like a true flagship. Its colorful faceplate, glossy finish, and smooth aluminum shell give it the kind of presentation you expect from a high-end IEM. Compared to U12t, it looks flashier and has more personality, especially if you prefer IEMs that stand out visually. Its shell is also smooth and ergonomic, so even with its ambitious internal design, Valhalla does not feel awkward in the ear.
By comparison, 64 Audio takes a more understated approach with the U12t. Its new stainless steel faceplate and T6061 aluminum shell give it a cleaner, brighter look compared to older U12t models. It is not as visually loud as Valhalla, but it feels more professional and timeless. A new silver cable and updated packaging also help make this version feel like a proper refresh rather than a simple reissue. When it comes to comfort, both IEMs are easy to wear, but U12t still has the edge for long listening sessions. 64 Audio’s shell design and apex pressure-relief system make it feel less fatiguing over time. Valhalla is comfortable, but U12t feels more purpose-built for daily professional and audiophile use.
Inside Valhalla is a 19-driver all-balanced-armature configuration per side. This includes four Sonion subwoofers, ten Sonion low-midrange drivers, four Knowles mid-treble drivers, and one Knowles ultra-treble tweeter. It also features a 4-way passive crossover and 4-bore acoustic tubing system. On paper, Valhalla is the more extreme design, which makes sense for Thieaudio’s flagship statement piece.
Rather than chasing the highest possible driver count, U12t uses a 12-driver balanced armature system with one tia high driver, one high-mid driver, six mid drivers, and four low drivers. It also includes 64 Audio’s tia acoustic system, APEX pressure relief, and LID circuitry. Its appeal comes from how well these technologies work together to create a consistent, balanced, and highly resolving sound. That contrast is one of the biggest differences between the two IEMs. Valhalla feels more like an engineering showcase, while U12t feels like a proven platform that has been refined over time.
Spatial presentation is strong on both IEMs, but each one handles scale differently. Valhalla has a large, expansive presentation with strong imaging and a big sense of space. Its 19-driver setup helps separate layers clearly, and you get a wide image that feels appropriately flagship-level. Music takes on an immersive quality, especially with dense arrangements and atmospheric tracks.
On the U12t 2025 Revision, imaging is still one of the main highlights. Its stage is wide, accurate, and very easy to read. With the new silver cable, this version has a slightly more open and breathable feel, making separation feel more pointed than before. It may not always feel as grand as Valhalla, but it is more precise. For critical listening, U12t gives you a more organized stereo field. In this category, Valhalla wins for size and spectacle, while U12t wins for accuracy and placement.
Bass is where Valhalla makes one of its strongest impressions. Thieaudio’s Precision Bass System gives the lows a stronger physical presence than you might expect from an all-BA design. It has weight, depth, and a satisfying sense of punch, but it avoids becoming too bloated. This gives Valhalla a more exciting and full-bodied foundation.
With U12t, the low end is more disciplined. Its bass is clear, fast, and reference-minded rather than huge or aggressive. It reaches deep, but it does not try to dominate the sound signature. For slam, Valhalla is more immediately satisfying. For control, texture, and bass that stays out of the way, U12t is the stronger choice. Personal taste matters most here. Valhalla is more fun and powerful, while U12t is more transparent and controlled.
Through the midrange, Valhalla has a smooth and slightly warm character. Instruments have good body, and vocals sit naturally within the mix without feeling too recessed or overly forward. Detail is very high, but Valhalla does not come across as sterile. Enough warmth is present to keep performances engaging while still giving you the resolution expected from a flagship IEM.
A more revealing approach defines the U12t’s mids. This has always been one of its strongest qualities, and the 2025 revision keeps that identity intact. Notes have excellent shape, instruments are easy to isolate, and vocals sound realistic without extra coloration. Compared to Valhalla, U12t does not have the same richness, but it offers a more neutral and accurate midrange. For musicality, Valhalla has a more inviting tone. For critical midrange detail, U12t is still hard to beat.
Treble on Valhalla is extended and refined without becoming overly sharp. It has plenty of air and clarity, but it does not push brightness too far. This makes Valhalla easy to listen to even with its high level of detail. Upper frequencies add space and definition without making the signature feel thin.
Higher frequencies on U12t have a more colorful presentation. Its treble glistens with excellent resolution, and the 2025 revision’s cable adds just a bit more sparkle. Even with that added brightness, U12t stays composed. Cymbals, strings, and high-frequency textures are given a more revealing edge, but the sound rarely becomes harsh. Overall, Valhalla is smoother and more relaxed up top, while U12t is more articulate and precise.
Both the Thieaudio Valhalla and 64 Audio U12t are excellent flagship IEMs, but they serve different listeners. Valhalla is more cinematic, powerful, and expressive, making it the more exciting listen. U12t is more balanced, accurate, and dependable, making it the better tool for critical listening and long-term reference use. For the more fun flagship, I would go with Thieaudio Valhalla. For the more complete and reliable flagship, 64 Audio U12t still earns its reputation as one of the best high-end IEMs available.
The 64 Audio U12t and the Thieaudio Valhalla are available at Audio46.
