HomeReviewsHeadphone ReviewsJBL Soundgear Clips Review
Open-ear earbuds continue to grow in popularity as more listeners look for a mix of comfort, awareness, and everyday convenience. Instead of sealing off the ear canal, this style is designed to keep you connected to your surroundings while still delivering wireless audio for music, calls, and workouts. JBL Soundgear Clips enters that space with a bold transparent design, modern Bluetooth features, app customization, and JBL’s recognizable consumer-friendly tuning. Let’s take a closer look at the Soundgear Clips to see how they perform in real-world use, from fit and battery life to soundstage, bass response, and overall value.
  • 1 x JBL Soundgear Clips earbuds
  • 1 x Charging case
  • 1 x Warranty / Warning
  • 1 x product QSG/ Safety Sheet
JBL Soundgear Clips single
The JBL Soundgear Clips are, in my opinion, among the best-looking open-ear earphones on the market. Both the earbuds and the charging case have a see-through design that looks very retro, like a product from the early 2000s. So in that area, the Soundgear Clip gets cool points. In terms of fit, these are still my favorite style of open-ear earphones. However, even with an easy clip-on design, the fit is slightly loose. They sit comfortably, but I did find myself adjusting them quite often.
JBL Soundgear Clips case open
The JBL Soundgear Clips use an 11mm dynamic driver, which is unusually substantial for an open-ear true wireless design and helps deliver fuller low-end response than many competing clip-style earbuds. JBL pairs the driver with its OpenSound acoustic platform and SonicArc geometry, which angles sound toward the ear while aiming to reduce leakage. An Adaptive Bass Boost algorithm further compensates for the natural bass loss common to open-ear headphones, giving the Soundgear Clips a more energetic and balanced presentation. Official specs list a 20Hz–20kHz frequency response, 32-ohm impedance, and 85dB sensitivity.
Through the JBL Headphones App, users can customize touch gestures, adjust call behavior, and fine-tune sound with six EQ presets or a full 10-band equalizer. This level of app control is especially useful for open-ear headphones, where placement on the ear can affect tonal balance and volume perception. The app gives the Soundgear Clips more flexibility than many lifestyle-focused wireless earbuds in the same category.
In practice, the touch sensors are very responsive. Using them feels natural, and after a short delay, the Clips give you satisfying feedback, letting you know the action has registered successfully.
JBL Soundgear Clips case closed
The JBL Soundgear Clips use Bluetooth 5.4, giving them a modern wireless platform with improved connection stability, lower power consumption, and efficient pairing performance compared to older Bluetooth generations. JBL also includes Multipoint connectivity, which allows the Soundgear Clips to stay paired to two devices at once. This is especially useful for users who bounce between a laptop and smartphone, since you can listen to music on one device and seamlessly switch to an incoming call or video meeting on the other. Codec support appears focused on the mainstream standards of SBC and AAC rather than higher-bandwidth options like LDAC or aptX Lossless.
The JBL Soundgear Clips are rated for up to 8 hours of continuous playback on a single charge from the earbuds themselves, which is strong endurance for an open-ear true wireless design. With the charging case included, total battery life extends to up to 32 hours, meaning the case supplies roughly three additional full recharges. JBL also includes speed charging, where a quick 10-minute charge provides up to 3 extra hours of playback.
JBL Soundgear Clips pair
Open-ear earphones should give you a wider soundstage than you’re used to with budget in-ear wireless buds. That’s exactly what happens with the JBL Soundgear Clips. I’ve been impressed with what JBL can do in terms of spatial imaging over their Bluetooth products, and the Soundgear Clips are no different. The soundstage presents a lot of breathable room for the stereo environment to exist in, supplying good width and separation for instruments and effects. It’s a linear stage with a good sense of channel identity, so everything feels natural without the imaging having a great scale to it.
Sometimes bass frequencies can get lost in the open air with these kinds of earbuds, but that’s not something the Soundgear Clip has too much trouble with. Everything feels pretty loose, but the tone still has some thump to it. Its presence is very consistent, providing a strong foundation of low-end frequency content that pools but has enough drive to lift the sound signature.
There’s plenty of space and fullness to the midrange for what the Soundgear Clips are. Instruments are given enough propulsion to stick out forward in the mix, all while not featuring the most resolving details. The mids are at their best with more relaxed music genres like folk and jazz, but heavier rock and electronic tracks can easily sound like a big smear. With that said, the fact that this audible smear is even that prevalent in the mix is pretty impressive considering most wireless earbuds tend to just dip the mids for a V-shaped sound profile.
Another area where the Soundgear Clips is very natural and lively is in the treble. Nothing feels bright or piercing, but the frequencies are clear and provide a good amount of energy that fits with the rest of the sound signature. They appear a bit thin, like other parts of the mix, but the highs are much more defined. You get more shape and structure to the treble than the bass and mids, so instruments don’t sound like a shimmery blur when tracks amp up the energy.
JBL Soundgear Clips succeed in offering a stylish and practical alternative to traditional earbuds. Their retro-inspired look stands out, the open-ear fit is comfortable for extended wear, and features like Bluetooth 5.4, Multipoint pairing, responsive touch controls, and strong battery life make them easy to recommend for everyday use. Sonically, they deliver an impressively spacious presentation with solid bass presence, clear mids, and smooth treble for this category. While they may not replace sealed in-ear monitors for maximum detail or isolation, the Soundgear Clips are a strong option for listeners who want awareness, comfort, and enjoyable sound in one package.
  • Stylish transparent design that stands out
  • Wide, airy soundstage with good imaging
  • Strong bass presence for an open-ear model
  • Clear, lively treble without harshness
  • Bluetooth 5.4 with Multipoint pairing
  • Excellent app features with EQ customization
  • Fit can feel slightly loose at times
  • No advanced codecs like LDAC or aptX Lossless
  • Mids can sound smeared on busy tracks
The JBL Soundgear Clips are available at Audio46.
