HomeLatest NewsMeet JBL's Reflect Aware C Noise-Cancelling Earbuds
Meet JBL’s Reflect Aware C Noise-Cancelling Earbuds
Forget a battery pack! JBL’s Reflect Aware C noise-cancelling earbuds draw energy from your phone.
The new sport headphones from the Harman run company will no longer require a separate charging adapter. Designed with the weekend warrior in mind, users are able to lighten their load thanks to JBL’s Reflect Aware C Noise-Cancelling earbuds which are refueled using a USB Type-C Connection, reports The Verge. This connection allows headphones to draw fuel straight from your mobile device.
I don’t know about you, but that feature alone gets me really excited.
The awesomeness does not stop there. These earbuds are not only noise cancelling – with the ability to adjust the amount of ambient noise you’d like to hear – but made with ergonomic ear tips a-la Jays x2 style, so you can totally get lost in your workout. The fin-like ear tips are designed for an exceptional fit that can withstand the vigor of any sport. Moreover, these sport buds are water resistant – sweat all you want!
To boot, the cable features an in-line mic and controller.
JBL’s Reflect Aware C noise-cancelling earbuds are said to run off of 14.8mm drivers.
At this time thee is no set release date on JBL’s Reflect Aware C noise-cancelling earbuds or the price tag, but we will be sure to let you know when we do.
Sade
Sade
