A long driver list can catch your attention, but an IEM needs a clear sense of purpose to keep it. The Kiwi Ears Astral brings a seven-driver hybrid configuration to a familiar resin-shell design, entering a crowded field where tuning, comfort, and technical performance all have to work together. For listeners who want to follow every layer of a recording without losing the enjoyment of the music, that balance matters more than specifications alone. Let’s see how convincingly those pieces come together.
- Kiwi Ears Astral Earphones
- 2-pin cable with 3.5mm and 4.4mm adapters
- Zipper carrying case
- S/M/L ear tips
- Extra filters
- User guide
Kiwi Ears doesn’t try to do anything too out of the ordinary with the Astral in terms of design. If you’ve tried other ChiFi IEMs from the likes of XENNES or Thieaudio, then this should look pretty familiar. It’s a design that works, from the universal shape of the ear cavity to the glossy resin of its outer material. The Astral is no different, just adding some unique faceplate artwork in either blue or green and pairing it with a nice cable. They’re nice to look at, nice to hold in your hand, and most importantly, nice to wear. It’s a snug fit for me, as the housing doesn’t move around a lot even when only lightly inserted. It’s a comfortable experience that goes along with the standard of Kiwi Ears and its related brands.
The Kiwi Ears Astral uses a seven-driver hybrid configuration in each earpiece, pairing a custom 10mm bioceramic-diaphragm dynamic driver for bass with six balanced armatures. Two dual balanced-armature units handle the midrange, while a modified dual SWFK tweeter covers the upper frequencies. A crossover at 300Hz integrates the dynamic driver with the midrange drivers, and a detachable 1.2-meter cable connects through two-pin sockets. The Astral is rated at 23 ohms impedance, with a specified frequency response of 10Hz–22kHz.
Listening to the Kiwi Ears Astral is like listening to a very clear and concise idea of where each sound should be in a mix. This is definitely Kiwi Ears’ most accurate soundstage I’ve heard, presenting spatial imaging as very concrete but with grace. The Astral allows the sound to breathe, even with more linear elements. It’s a style of studio-like presentation that makes the sound very direct and individualized, all while featuring ample space for the elements to feel full and realized in the mix. You can easily decipher the layers yourself, as the level of separation is very pronounced. This works to really identify what’s coming from the left and right channels with ease, giving tracks a proper width, as the imaging gives you a pinpoint look into where all the sounds are positioned in the stereo field.
If you’re looking for accurate bass with some heft, the Astral is a perfectly suitable option. The low frequencies are very grounded, with a natural tone that fits itself into the mix well. It’s a very balanced response that has a good thud to it, which keeps you engaged in bass notes and grooves. Presence is maintained by strong clarity and detail, showing a low end that has a distinct shape. Sub-bass frequencies aren’t as gratifying as the mid-bass, but the size and ressonance of the bass are big enough to give you a faithful and fun distribution of low-end information. Impact is tight but rich, always hitting hard when it needs to and making space for other instruments to stack on top of it. This makes for a dynamic response that maintains composure while feeding you satisfying bass tones for pure pleasure.
While not as striking as it feels like it should be, the Astral’s midrange is still very clean. Some of the frequencies come off as slightly mellow, but still timbrally refined. You get good detail from instruments, but they are also tonally flat. This has positive and negative results, with most of the negative results not being major issues at all, just slight setbacks. This flatness keeps the frequencies even, following the balanced and natural sound signature the Astral’s tuning is going for. You still get a sense of surface area to the instruments, and they possess good body; they just aren’t projected forward. The low mids don’t really have a texture, but the frequencies are still well defined. Clean electric guitars twang and ring out well, and you get the fullness of the instruments without it featuring that much of a significant cut into the mix. It’s really the vocals that will make the strongest impression on you, as the Astral delivers resolving, expressive voices with clear enunciation for an intimate performance.
The Astral has a very clear and digestible treble that has a sort of sweetness to it. It has an airy timbre that keeps its sizzle restrained but still glistens in the mix. They don’t draw too much attention, but when you focus on them, they offer plenty of rewarding qualities that complete the Astral’s sound signature. Everything feels elevated, allowing the highs to occupy a more open headspace. This makes detail easy to manage and localize, while featuring a tame tonality that lets you enjoy a critical response without fatigue.
The Kiwi Ears Astral makes its strongest impression through the clarity of its spatial presentation. Precise imaging and well-defined separation give each instrument a distinct place, making busy arrangements easy to follow while preserving room for the music to breathe. Tight, weighty mid-bass adds satisfying impact, vocals sound expressive and intimate, and the airy treble reveals detail without becoming demanding. Its comfortable, secure fit rounds out an experience that’s easy to settle into.
There are a few areas where the Astral could offer more. Deep sub-bass is less gratifying than its mid-bass punch, and instruments in the midrange can feel a little mellow, lacking the texture or forward presence some listeners might prefer. Even so, those reservations don’t overshadow its strengths. For listeners who prioritize accurate imaging, controlled bass, and a balanced sound signature, the Kiwi Ears Astral is a compelling hybrid IEM that rewards close listening.
The Kiwi Ears Astral is available at Audio46.
