HomeReviewsAudiophile ReviewsAstell & Kern x Volk Audio Stella Review: Luxury IEMs With Vivid...
Astell & Kern x Volk Audio Stella Review: Luxury IEMs With Vivid Detail
Luxury materials and an elaborate driver configuration can make an IEM look impressive, but the real test is what happens when you start listening. Astell & Kern’s collaborations have brought some distinctive names into the world of high-end in-ear monitors, and its latest partnership with Volk Audio continues that tradition. The Stella Limited Edition arrives with plenty of ambition, joining a competitive field where expectations extend well beyond striking looks. For an IEM at this level, the listening experience needs to leave a lasting impression. Let’s explore how it comes together and what it offers listeners searching for their next flagship earphones.
  • Astell & Kern X Volk Audio Stella earphones
  • Custom 4.4mm 2-pin cable
  • Zipper case
  • Double mesh drawstring bag
  • S/M/L foam tips
  • S/M/L Silicone tips
  • Cleaning cloth
Astell & Kern x Volk Audio Stella single
A&K collaborations almost always mean you’re going to get good-looking IEMs. Volk Audio Already has a knack for building some fancy-looking earphones if the Étoile is anything to go by. Even with all of its fancy materials, my first impression of the Stella was its weight and size. I expected these earphones to have some heft, but they are actually quite light, and their size seems pretty standard for most IEMs. Yes, the design is much busier than most, but the Stella still seems practical as something that still needs to fit inside your ear.
For its build, the Stella uses machined 6061-T6 aluminum shells with a satin-black anodized finish, providing a lightweight, rigid structure designed to control vibration. Each faceplate combines an aluminum central plate with a diamond-polished 9H sapphire crystal glass panel and a mirror-polished 316 stainless-steel frame. In terms of comfort, the Stella is stable and easy to wear. The housing protrudes outward, but with the right tips, your ears shouldn’t feel stretched.
Astell & Kern x Volk Audio Stella cable
The Stella features a 12-driver quadbrid configuration combining one 9mm dynamic driver, five Sonion balanced armatures, two planar magnetic drivers, and four Sonion electrostatic tweeters. A six-way crossover and five precision sound tubes coordinate the drivers, while internal damping and tuned vents manage resonance and pressure.
  • Frequency Response: 10 Hz – 45 kHz
  • Sensitivity: 103.8 @ 1 kHz
  • Impedance: 7.17 Ω @ 1 kHz
Astell & Kern x Volk Audio Stella pair
Some high-end IEMs aim to immerse you in a dimensional soundstage that wraps around you to simulate a natural environment. Other IEMs are meticulously engineered to give you the most accurate representation of a mix possible. The Astell & Kern X Volk Audio Stella is more of the latter, and it uses its soundstage to execute that in the best way possible. At first, the Stella may come off as a little too linear and closed off, but it makes up for that lack of headspace with pinpoint sound placement and articulation.
This is a soundstage that is very punctual in its spatial accuracy, anchoring instruments and nailing them down to a carved-out spot in the sound spectrum just for that particular sound. Everything is layered around it with cohesion, stacking and curving around each other with enough space between them to really fill out the scope of the mix. Even though there’s not this huge sense of openness with the Stella, you still get a wide wingspan with channel identity. Instruments panned hard left and right feel like they occur at the edge of the shells, while keeping their natural scale in terms of tallness. Nothing sounds thinned or stretched out, resulting in a sensation that emulates more of a live room in a studio as opposed to a live venue.
While the Stella isn’t the most bass-heavy sound, it has a good amount of clarity and detail that will keep you engaged. The majority of its prominence comes from the sub-bass, which does a good job establishing a surface tonal identity that the bass can rest on when the mid-bass can’t really deliver on impact. With the Stella’s sub-bass detail, you can feel the physicality of kick drums, but it’s still a bit gentle, even though their presence in the mix is definitely highlighted. Bass guitars have a neutral timbre where you can feel an underlying groove that makes the notes appear full, but their texture is very flat. It makes the bass feel like a soft blow in the sound signature. You get a good amount of frequency content here, and although it has a clear pulse, you’ll never hear it provide any significant body.
By far, the richest part of the Stella’s sound signature is its midrange. It’s a natural presentation with a great combination of low-mid warmth and microdetail that will easily entice listeners looking to be immersed by instrumental realism and artifact clarity. This isn’t just raw detail either. The timbre of the mids is very textured, with very intimate qualities thanks to the expansion and control of its low-mid frequencies. It gives the sound signature a real character, combining its sonic closeness with transparency for a particularly vivid midrange resposne. Individual notes are very tangible, attacking with a clear snap and sustaining with superb fidelity. Transients operate in the mix with great finesse, giving the mids tightness and realism throughout. Vocals receive a lot of positive attributes from this, as the Stella places them directly in front of you for a really intense sense of definition.
Some might find the treble to be a bit too hot, but if you find yourself not being too sensitive to these frequencies, then the Stella will be quite pleasant here. I find the highs to be very graceful, delivering crispy frequencies that are maintained to never get too bright or peaky. It’s not quite shimmery, but the frequencies have a flavorful glimmer to them that gives the highs some color on top of their already fabulous resolution.
The Astell & Kern x Volk Audio Stella makes its strongest impression through its midrange, where natural warmth, vivid vocal definition, and finely resolved transients give music a tangible presence. Its imaging is equally compelling, placing instruments with precision within a soundstage that favors intimacy over expansive depth. Clear sub-bass adds a gentle physical foundation, although listeners seeking substantial bass weight or punch may find the presentation restrained. The detailed treble brings welcome energy and color, but its intensity could be a sticking point for treble-sensitive ears.
Combined with its elaborate materials and surprisingly manageable fit, the Stella offers an appealing balance of luxury construction and focused sound. For listeners who prioritize instrumental realism, articulate layering, and close attention to the details of a recording, these flagship IEMs have a distinct appeal.
The Astell & Kern X Volk Audio Stella is available at Audio46.
