HomeReviewsHeadphone ReviewsZiiGaat x Hangout.Audio Odyssey II Review: A Hybrid IEM That Punches Above...
ZiiGaat x Hangout.Audio Odyssey II Review: A Hybrid IEM That Punches Above Its Price
The ZiiGaat x Hangout.Audio Odyssey II enters this competitive, affordable IEM space, aiming to deliver a premium feel and high-performance sound at an accessible price point. With a hybrid driver configuration, handcrafted design elements, and a tuning geared toward musical engagement, the Odyssey II positions itself as an option for listeners who want both style and substance. But how well does it actually perform where it matters most?
  • 1 x ZiiGaat x Hangout.Audio: Odyssey 2 IEM
  • 6 × Pairs of silicone ear tips (S/M/L, black and transparent)
  • 1 × Pair of foam ear tips (S/M/L)
  • 1 × High-Performance 4-Core OFC + Silver Litz Cable
  • 2 x Pairs of replaceable filters
  • 1 × Premium carrying case
  • 1 × 3.5mm plug
  • 1 x 4.4mm plug
  • 1 × Warranty card
  • 1 × Wearing diagram/user instruction card
ZiiGaat x Hangout.Audio Odyssey II single
There are a few different IEMs in this price range with builds that aren’t just plastic shells, but the Odyssey II really stands out here. The shell is handcrafted and made from aluminum alloy. Its faceplate is a hand-poured resin, each one being totally unique, so no two designs are the same. This is a winning combination for a better-than-usual IEM design for the price, but what makes the Odyssey II really stand out is its size. The housing is compact, looking like something you can actually see inserted into your ear. The result of that is a comfortable fit that feels secure and natural. They hold in place, and the spout is short enough not to feel too intrusive.
ZiiGaat x Hangout.Audio Odyssey II cable
The Odyssey II is built around a hybrid five-driver configuration that combines one 10mm second-generation bio-cellulose dynamic driver with three Knowles balanced armature drivers.
  • FREQUENCY RESPONSE RANGE: 20 Hz – 25 kHz
  • IMPEDANCE: 20 ohms
  • SENSITIVITY: 105 dB
  • TOTAL HARMONIC DISTORTION (THD): 0.19%
ZiiGaat x Hangout.Audio Odyssey II pair
In terms of scope, the Odyssey II spans widely, displaying a soundstage that cuts across the stereo field with scale. While not featuring the most non-linear spatial imaging, the soundstage pushes the sound elements forward, communicating fullness without much depth. You get a flat but focused level of accuracy as a result, as the Odyssey II has no trouble articulating layers of arrangements in a comprehensible fashion. The Odyssey is very balanced in terms of channel separation, and the space between different instruments is carved out well enough for an IEM in this price range. The level of headspace won’t completely immerse you in the sound, but the pinpoint precision and positional anchoring of specific sound elements more than make up for it.
The bass has a very satisfying drive to it, delivering low-end frequencies big and fast. Its tone is thick without being overbearing, only using its impact to drive itself deeper in the mix. While not featuring an underlying rumble in the sub-bass, the lows are placed firmly and resonate well in the mix. With its quick transient response, the Odyssey II finds a way to be large and tight with its envelope, giving off a good sense of dynamics with its punch.
With the forward propulsion of the midrange, the Odyssey II becomes one of the best options for rock, pop, and electronic music. You get such a full, rich response that handles elements like distortion with a striking level of rawness. Everything comes in with a realistic presentation, never dissolving into a gloomy smear. The mids are propped up with natural tonality and have a physical response that supplies a clear shape to each instrument. Nothing ever gets set aside, as each instrument receives the same amount of energy throughout the sound signature. If you’re focused on good vocal resposne, the Odyssey II features a very expressive response that puts them in an intimate space. At times, it can feel like the singer is directly in front of you.
The highs keep up the energy of the Odyssey II’s sound signature without feeling harsh. They extend even while not substantially increasing height, delivering a collection of frequencies that are clear and concise. It has an airy timbre with some light sparkle on cymbals and bells.
The ZiiGaat x Hangout.Audio Odyssey II proves to be more than just a visually striking IEM—it delivers a well-rounded sound signature that emphasizes impact, clarity, and musicality. Its hybrid driver setup translates into a dynamic listening experience, with punchy lows, forward and expressive mids, and crisp yet controlled highs. Combined with its comfortable fit and premium construction, the Odyssey II stands out as a strong contender for anyone searching for a versatile in-ear monitor in this price range. Whether you’re into rock, pop, or electronic music, the Odyssey II offers a compelling balance of technical performance and engaging sound that makes it easy to recommend.
Major Hifi Silver
The ZiiGaat x Hangout.Audio Odyssey II is available at Audio46.
