HomeReviewsGaming Headphone ReviewsBeyerdynamic MMX 230 Review: 60-Hour Battery Life Meets Premium Gaming Sound
The wireless gaming headset market is crowded with options, but few brands carry the audio reputation of Beyerdynamic. Known for studio headphones and respected gaming models, the company enters a more lifestyle-focused space with the MMX 230. Designed for players who want dependable wireless connectivity, long battery life, active noise canceling, and the comfort to wear for hours, this headset aims to balance gaming performance with everyday practicality. Let’s break down its build quality, microphone performance, sound signature, and whether it delivers enough value to stand out among today’s best wireless gaming headsets.
  • MMX 230 headphones
  • 1.8m USB-C cable
  • USB-A to USB-C adapter
  • Low-latency USB-C dongle
  • Drawstring bag
Beyerdynamic MMX 230 headband
The MMX series usually maintains a good build quality, especially the 300 and 330. The 230 is a bit more scaled back with more plastic parts, reminding me more of your usual piece of gaming gear, aside from a few aspects. The ear cups feel very refined, and they take their design from the Aventho 300 and attach a microphone to it. This makes for a sleek design that’s also very lightweight, and by adding soft velour ear pads to it, the MMX 230 becomes one of the most comfortable gaming headphones you can buy. My only slight criticism would be that the microphone isn’t detachable, even though I like how it clicks into place to mute and unmute the mic.
Beyerdynamic MMX 230 above
The MMX 230 utilizes a 40mm dynamic driver that covers a 20Hz–20kHz frequency response, giving it full-range capability for both gaming and everyday media use. At the same time, the closed-back acoustic design helps reinforce bass impact and improve immersion by reducing outside distractions. Noise-canceling will also help with that, and it’s very effective. You can argue that it’s too effective, in that it can reduce the fidelity of the output. Other features include EQ, multipoint Bluetooth, and low-latency wireless connection through its USB Type-C dongle. It also has a pretty impressive 60-hour battery life, so you can use the MMX 230 for multiple long gaming sessions before you need to charge it.
Mic Quality
Beyerdynamic’s MMX 300 and 330 models are the standard for good onboard mics on gaming headphones. Unfortunately, the MMX 230 doesn’t meet those standards. On playback, the response is pretty low fidelity, but still distinguishable. It’s fine if you’re just looking to simply chat with your friends or other people in a multiplayer game lobby, but it’s not ideal for recording your voice.
Beyerdynamic MMX 230 side
Beyerdynamic’s gaming headphones have been better than average compared to what’s on the market. With the MMX 230, it feels like a slight step back, but still more accurate than most consumer headsets. Channel separation is good, but the overall width is brought in close to you, rarely conveying an expansive headspace. That might be dissapointing for those looking to be immersed in your game audio, but the MMX 230 is still very good at individualizing musical and sound design elements. The spatial imaging displays clear positioning within its limited scope, featuring precise movement and discernible layers. Music, effects, and dialogue all get their space to shine.
Funnily enough, if you’re using the MMX 230 to listen to music, the soundstage actually feels more expansive. Everything has a slightly roomier presentation that is more in line with studio headphones. It’s a more natural stereo environment, with spacious properties that are more musically immersive than how games can be with ambient sound design. Using spatial audio with the PS5 helped a bit with that immersive quality, but I was still never that impressed.
Gaming headphones really need to deliver in the low end to heighten cinematic moments and deliver a satisfying response. Thankfully, the MMX 230 does just that, with a buttery smooth thump that feels rich and exciting. The frequencies resonate with impact and definition, all while relegating themselves to a distinct area where they can’t bleed into the rest of the sound signature. It balances expressive tone with tight control very well, delivering enticing rumble when the moment calls for it, and maintaining a subtler presence on the opposite end of the spectrum. This keeps the lows at a consistent shape that surpasses a lot of the muddiness you’ll hear with other gaming headphones. The MMX 230 is more elegant and articulate with its bass detail, but it also has the texture needed to add that layer of color that allows the frequencies to bloom cleanly.
The midrange is pushed forward very aggressively, keeping everything out of the background for an even and voluminous display of sound. Some of it can appear a bit muffled and artificial, but the low-mids and upper-mids retain a solid weight to them that allows the frequency resposne to appear full and impactful. Musical notes have good texture, and foley is very clear even when not at the highest fidelity.
Footsteps are loud and have a clear strike to them. It shows off a level of finesse with transients that is rare for a lot of gaming headphones. The only area where the midrange feels a bit weak is with voices. Dialogue should stick out in front of the mix, but on the MMX 230 its placed between the music and sound effects. I never had trouble discerning voices, but I prefer when they’re raised in the sound signature for more clarity.
When you think of Beyerdynamic, you might imagine a very lively treble. Too lively for some. While the MMX 230 definitely has some present high-end detail, its timbre is airy instead of bright. This is much more fitting for gaming headphones, as the treble is tuned to be more reserved, while it still expresses satisfying sizzle and crispness in a way that is easier to consume. The roll-off is very apparent, but the flavor is still there.
The Beyerdynamic MMX 230 succeeds where it matters most for modern gamers: comfort, battery life, reliable wireless performance, and a fun sound signature without becoming messy or fatiguing. Its bass response adds excitement, the mids keep important in-game details present, and the treble remains smooth enough for long sessions. Add in effective noise canceling and a lightweight fit, and it becomes an easy headset to live with day to day.
Its microphone quality may not match the higher-tier MMX models, and players looking for a huge, cinematic soundstage may want more width. Still, for users who want a versatile wireless headset that can move between gaming, music, and casual media use, the MMX 230 is a strong contender. If comfort and balanced everyday usability matter more than flashy gimmicks, the MMX 230 is one of the smarter gaming headset choices in its class.
  • Extremely comfortable lightweight fit with soft velour ear pads
  • Strong 60-hour battery life for long gaming sessions
  • Effective active noise canceling helps immersion
  • Smooth, punchy bass with good control and texture
  • Clear imaging and solid positional accuracy for games
  • Multipoint Bluetooth and low-latency USB-C dongle add versatility
  • Sleek, modern design inspired by higher-end Beyerdynamic models
  • Microphone quality is lacking
  • Soundstage lacks a wide, expansive presentation
  • Some mids can sound slightly muffled or artificial
The Beyerdynamic MMX 230 is available at Audio46.
