HomeReviewsBest Noise Cancelling HeadphonesSennheiser Momentum True Wireless 5 vs Sony WF-1000XM6 Comparison Review
The Sennheiser Momentum True Wireless 5 and Sony WF-1000XM6 are two flagship wireless earbuds built around premium sound, active noise cancellation, and extensive Bluetooth features. However, each model approaches those priorities differently. Sennheiser emphasizes comfort, powerful bass, aptX Lossless, and long-term usability, while Sony offers more expansive imaging, advanced software features, and some of the strongest noise cancellation available from true wireless earbuds. Which pair is the better choice? Let’s compare the Sennheiser Momentum True Wireless 5 and Sony WF-1000XM6 in terms of design, functionality, battery life, and sound quality.
Momentum True Wireless 5 WF-1000XM6
  • One pair of MOMENTUM True Wireless 5 earbuds
  • One charging case
  • One USB-C charging cable
  • Ear tips (XS/S/M/L)
  • Battery replacement tool
  • Documentation
  • Bathys over-ear headphones
  • Zipper carrying case
  • 3.5mm to 3.5mm cable
  • USB Type-C to Type-C cable
Sennheiser Momentum True Wireless 5 vs Sony WF-1000XM6 single
Sennheiser has significantly streamlined the Momentum True Wireless 5. Its narrower housing feels less cumbersome than previous Momentum earbuds, while the removal of the exterior rubber component gives the design a cleaner appearance. The earbuds sit securely and remain comfortable during extended listening sessions, making the updated fit one of their most meaningful improvements.
The WF-1000XM6 moves in the opposite direction. Sony has enlarged the housing, reportedly to accommodate its expanded microphone system. Although the earbuds remain wearable, they can feel looser and less secure than the smaller WF-1000XM5. The supplied foam tips may also make it more difficult for some listeners to achieve a proper seal. When it comes to overall comfort and stability, the Momentum True Wireless 5 has the advantage. Its slimmer build is easier to position and better suited for long listening sessions. Fit will always vary between listeners, but Sennheiser’s design feels more universally accommodating.
Sennheiser Momentum True Wireless 5 vs Sony WF-1000XM6 case closed
The Momentum True Wireless 5 uses Sennheiser’s 7mm TrueResponse dynamic driver, with a listed frequency response of 5Hz–21kHz. Its adaptive noise cancellation is stronger than previous Momentum generations and includes automatic wind-noise suppression. Four microphones per earbud, beamforming, a voice accelerometer, and AI-assisted voice isolation are also used to improve call quality. Sony equips the WF-1000XM6 with refined dynamic drivers and its HD Noise Cancelling Processor QN3e. This system works alongside multiple microphones to suppress environmental noise, producing an exceptionally powerful isolating effect. Even nearby vibrations and intrusive background sounds become difficult to notice once ANC is active.
The XM6 also has a more extensive collection of software features. DSEE upscaling, 360 Reality Audio, customizable EQ, activity-based listening, and spatial sensors for augmented-reality gaming are all included. Sennheiser offers a well-rounded feature set of its own, including EQ and Dolby Atmos spatial audio, but Sony provides more ways to personalize how the earbuds behave. For active noise cancellation and smart features, the WF-1000XM6 is the clear winner. Sennheiser’s ANC is highly effective, but Sony creates a more complete sense of silence.
Both earbuds offer premium wireless performance. Sennheiser has the edge for listeners invested in aptX Lossless, while Sony’s LDAC and LE Audio support may be more useful across a broader selection of Android devices. The Momentum True Wireless 5 supports Bluetooth 6.0, multipoint connectivity, aptX Adaptive, and aptX Lossless. This makes it an especially attractive option for listeners with compatible Android phones and other aptX-capable devices. Sony uses Bluetooth 5.3 and supports LDAC for high-resolution wireless playback. Bluetooth LE Audio and LC3 support add the potential for lower latency, improved efficiency, and Auracast compatibility when paired with supported devices.
The Momentum True Wireless 5 lasts for up to 12 hours with ANC turned off or approximately six hours with ANC enabled. The charging case extends total playback to as much as 40 hours. An eight-minute quick charge provides around one hour of playback, while USB-C and Qi wireless charging are both supported. Sony rates the WF-1000XM6 for approximately eight hours with ANC active and 24 hours in total with the charging case. Sony provides longer listening time per charge when noise cancellation is enabled. Sennheiser offers substantially more total battery life through its case, however. More importantly, the batteries inside both the Momentum True Wireless 5 earbuds and charging case are replaceable, giving Sennheiser a major advantage in longevity.
Sennheiser Momentum True Wireless 5 vs Sony WF-1000XM6 pair
The Momentum True Wireless 5 has an organized and controlled soundstage. Its stereo field is not exceptionally wide, but individual sounds occupy clearly defined positions. Instruments wrap around one another without becoming crowded, creating a layered presentation with good depth and separation. Sennheiser’s Dolby Atmos mode is less successful. It draws some stereo information toward the center before pushing other elements outward, producing an effect that can feel more processed than immersive. Standard stereo playback offers a more natural and coherent presentation.
Sony produces the larger and more dimensional soundstage. The WF-1000XM6 establishes clearer left and right boundaries while giving instruments enough room to maintain their individual identities. Added height and inward depth create an expansive bubble of sound without requiring spatial processing. Both earbuds image accurately, but the WF-1000XM6 is more spacious and immersive. The Momentum True Wireless 5 remains precise and cohesive, while Sony makes the sound feel larger.
Bass is one of the Momentum True Wireless 5’s biggest strengths. The low end is thick, smooth, and physical, with enough restraint to avoid overwhelming the rest of the mix. Sub-bass adds foundational weight, while the mid-bass delivers rich textures that complement bass guitars, synths, and electronic percussion. Resonance is controlled, but Sennheiser never sacrifices the satisfying bloom associated with the Momentum series.
The WF-1000XM6 also produces a thick and impactful bass response, but Sony has tightened its presentation compared to previous generations. There is less fog surrounding the lows, resulting in cleaner hits and greater perceived detail. It still retains the weight and boominess traditionally associated with the WF-1000X series, but the tuning sounds more concentrated. Sennheiser offers a smoother, deeper, and more satisfying bass response. Sony’s bass is cleaner than before, but it does not have quite the same physicality or tonal richness.
The Momentum True Wireless 5 features a warm midrange led by the lower mids. There is enough control to prevent this warmth from becoming bloated, and plucked instruments receive a pleasant sense of texture. The presentation is clean and full, although it does not reveal an exceptional amount of fine detail. Sony’s midrange is clearer and more resolving. Instruments have better-defined characteristics, while vocals sound more forward and articulate. The upper mids can occasionally become intense, but this energy also helps vocals sound especially expressive. Listeners sensitive to this region may want to make a few adjustments with Sony’s EQ. The WF-1000XM6 wins for midrange clarity and vocal detail. The Momentum True Wireless 5 is warmer and more relaxed, which may be preferable for longer sessions, but Sony communicates more information.
Sennheiser’s highs are crisp without becoming fatiguing. Percussion has a defined click, and cymbals retain enough sparkle to sound lively. The treble eventually rolls off, limiting airiness but helping the overall tuning remain cohesive and controlled. Sony takes a brighter approach. The WF-1000XM6 has the most prominent treble of any WF-1000X earbud, adding detail, energy, and air to the sound. This makes the XM6 feel more articulate, but the highs can also become aggressive for sensitive listeners. Sony’s EQ can soften the response when necessary. The better treble performance comes down to preference. Sony offers more energy and apparent detail, while Sennheiser provides a smoother and more forgiving balance.
The Sony WF-1000XM6 is the stronger technical performer. It has more powerful active noise cancellation, a wider soundstage, clearer mids, and a more extensive collection of smart features. Its brighter, more articulate sound gives music a greater sense of openness and detail, although its larger housing and energetic treble may not suit everyone. The Sennheiser Momentum True Wireless 5 is the more comfortable and musically relaxed alternative. Its secure fit, deep bass, controlled highs, aptX Lossless support, longer total battery life, and replaceable batteries make it particularly appealing for extended everyday use.
Choose the Sony WF-1000XM6 if you prioritize class-leading ANC, spacious imaging, vocal clarity, and advanced features. Choose the Sennheiser Momentum True Wireless 5 if you value comfort, richer bass, smoother treble, aptX Lossless, and better long-term serviceability. Overall, the WF-1000XM6 earns the narrow victory for its superior noise cancellation and more revealing sound. However, the Momentum True Wireless 5 may be the better all-day earbud—and the safer choice for listeners who find Sony’s brighter tuning or larger fit less accommodating.
The Sennheiser Momentum True Wireless 5 and the Sony WF-1000XM6 are available at Audio46.
